Difference Between SBC & LT1
Old May 8, 2008 | 09:10 PM
Prototype007's Avatar
Default Difference Between SBC & LT1
I am not having any luck whatsoever trying to search and find out the difference between the rotating assemblies of an older 1 piece rotating assembly and one for LT1?
What is the difference?
Can we use whole rotating assembly's from older SBC in our LT1 blocks, Like a 383 or 355?
Old May 8, 2008 | 10:32 PM
LT1_Fireman's Avatar
As long as its a one piece rear main I think the answer is yes.
Old May 9, 2008 | 03:01 AM
Mojave's Avatar
LT1 bottom end is exactly the same as a 1 piece rear main seal SBC. So that means any 1 pc RMS SBC part will fit an LT1: crank, rods, pistons, oil pump, etc, etc.
Old May 9, 2008 | 11:59 AM
Well I mean I got to reading the specs like rod length and actual crank throw and it all measures out to be the same. Only thing I have found different is LT1 has shorter skirt on the piston than an older SBC.
Thought rod and wrist pin location may be different between the 2 generations.
Anyone else have any knowledge on this because I'd really hate to buy a kit and then not be able to use it.
Old May 9, 2008 | 06:06 PM
Bump for some others input.
Old May 9, 2008 | 06:35 PM
Formula350's Avatar
heh How many more people need to tell you they're the same?
I'll up the count to 3, for ya.
Old May 10, 2008 | 02:08 AM
As many as possible. Surely there has to be some difference or else a lot of people would be doing this because older SBC kits are cheap for forged parts.
Old May 10, 2008 | 02:12 AM
daniel6718's Avatar
id assume so all the other internal parts are the same...only thing differant on a lt1 is the cooling passages..afr heads are actually modified sbc ones with cooling passages modified to work on lt1
Old May 10, 2008 | 02:23 AM
Yeah I mean the only other difference I have found is the reverse coolant passages, but I mean something can't be right if you were to take a rotating assembly from a small block and place in our LT Blocks, or else it would be done by people all the time.
Old May 10, 2008 | 07:29 AM
Mojave's Avatar
It IS done by people all the time. The 383 LT4 I'm building has an SBC rotating assembly.
Let me be perfectly clear: IT IS THE SAME. BUY AN SBC ROTATING ASSEMBLY. IT WILL WORK. I PROMISE.
Old May 10, 2008 | 08:36 AM
Formula350's Avatar
Yea, people do it a bunch, sites just list as "LT1 Stroker" to get a few more bucks out of you.
Old May 10, 2008 | 09:22 AM
caldercay's Avatar
For a simple example, download and read through the Eagle catalog:
http://www.eaglerod.com/2008%20Eagle%20catalog.pdf
And search where, in the catalog, you see specific kits/parts for the LT1; if
you find LT1-specific parts, please point to it. (Yes, there are a couple of
exceptions mentioned, such as, "not for LT1").
Old May 10, 2008 | 11:20 AM
LET ME BE PERFECTLY CLEAR!!!!!!!
Thanks for the help guys lol! I'll dance at ya'lls weddings.
