big trouble pushrod/guideplate related
hey guys, i just finished building up my 355 and got her running right, well i thought so anyways. I havent driven it hard yet but it seemed like it was down on power a little bit and i thought i heard a loose rocker "1.6 gm performance rockers" so i pulled the valve covers. Well a few were a little loose so i tightened them all back down, but before i put the valve covers back on i closely looked at one of the pushrods and it has grind marks at the top from rubbing on the guideplates.
I have stock lifters, stock 7.20 pushrods and the guy over at comp said these would work fine. I took the intake off to see if there were any metal shavings down in my motor and come to find out there are a bunch of shavings down by the lifters.
WHAT DO I DO?? i know i need some new pushrods,.
How do i get most the metal shavings out of the motor without pulling the whole thing?
Yeah, I used hardened pushrods on mine... Also, some guideplates are "adjustable." In other words, the holes where the rocker studs go in are oblong. Maybe you have one slightly off center?
as mentioned, you need "hardened" PR and guide plates. GM guide plates are not hardened.
I use the ISKY adjustable guide plates which are helpfull in getting the RR tip dead center on the valve and Trick Flow hardened PR.
If you see metal shavings in the lifter valley do the best job you can in removing debris. maybe pull lifters and clean them. Run motor a few times with back to back oil changes. Check magnet on drain plug and cut open filter and see what it collected.
Hopefully all the shavings stayed up in the lifter valley..
I say that because I have the GMPP roller rockers and mine are self aligning, although they could make the non self aligning. I just don't know, off the top of my head....
Hey guys, thanks for all your help...
The guy over at comp wasnt very helpful when it came to telling me about what i need and what i didnt need. I told him that i had stock pushrods and self aligning rockers and he said that everything would work out fine.
But when i called him today he said that i needed hardened pushrods and nsa rollerrockers. Guess his head was in the wrong place and hopefully it doesnt ruin my brand new damn motor..
KEEP THE IDEAS COMING!!@! thanks alot guys!
We need to know for sure what kind of rockers you actually have.
If self aligning - normal pushrods will work, do not use guideplates
If non self aligning - guideplates and at least a hardened pushrod.
I would recommend using any one piece 5/16 .080 wall pushrod so long as it is the proper length regardless of rockers.
when I put roller rockers I used the GMPP guide plates and Comp 1 piece hardened pushrods and I have 1.65 NSA rockers, and I have zero rubbing or shavings,
my only advice would be to chunk the aluminum cheapo rockers.
I have the self aligning rockers that come with the lt4 hotcam kit, For now i am going to try to get all the metal out that i can and clean the lifters, take off the guideplates untill i can get some nsa rr's.
Btw i got new comp hardened pushrods today
