Stock LT1 fuel pump
Car has extend crank and stumbles on start up. Runs good once car starts up. With fuel pressure gauge hooked up, noticed wasnt holding pressure with key on engine off and while running when i snap the throttle went from 33psi to 41psi, also tried removing regulator vacuum and went to 41psi (should have gone to at least 45psi).
Good idea, and I do the same thing. I also change my fuel filter annually, so the pump never has to work harder against a clogged filter.
1: Where can I get just the pump for that price
2: The only mods that are going to be done to this car is a CAI with long tube headers, catted Y, 3 inch full exhaust (borla) So is it even necessary to get a high flow fuel pump when I wont even need it? What affects will it have on the car pumping all that gas that is not needed?
You do not need an aftermarket pump with just those mods. Now if yours is going out it will be a good upgrade. The only time you might need one is if and when you do cam and head work, Nos, pro charger and are going for high hp. etc etc..
