94 camaro 6 speed building a engine for 12s
hi guys, i just bought a 94 camaro 6 speed with a blow head gasket, the car has 170xxx miles. i want it to be my daily drive car but i also i want it to run in the 12s, i wnat to keep my a/c adn my 3.42 gears. whta kind of cluth will i need, cam, valve spring, will i be able just to get it .30 over and use the saem rods adn crank, or should a but a eagle kit,
I live about an hour south of you on 360. I'll be glad to lend you a hand and help you find parts for it. You should be able to break 12s with just bolt ons on your stock rear/gearing, but you may want to look into a cam depending on how deep you want to go into the 12s. Just pm me and let me know your thoughts and we'll go from there. Good luck.
its not hard to put an lt1 in the 12s.bolt-ons and decent cam will get you deep into the 12s. i went with advanced induction's 226/234 cam. i love this thing. and if you buy the kit, it takes out all the guess work. im expecting atleast 12.5 next time i hit the track
what kind of cam is that? Part #
I couldn't agree more with you about the 12s. I was just suggesting the time because you mentioned staying with stock rear/gearing. That will limit your launch unless you like replacing the 10 bolt..LOL Cam only LT1s easily belong in the low 12s and a 12.5 will be an easy feat. Like I mentioned, I'll be glad to give you a hand or help find your needed parts.
