Another misfire, opti or coil or o2's??
Hey everyone I recently developed a misfire again. I have new plugs and new wires and they are good. However the opti, coil, and o2 sensors are original with 135,000 miles on them. The mis is not too bad at idle but under load it feels like its on seven cylinders and backfires a lot. I'm not showing an ses light either. Any help would be great. Thanks
What year your car is might help. If it's obd-1 year, you won't get codes anyhow. You say it happens at idle and under load, but at what rpms under load, it being a high or low miss could get you different answers.
Start with the cheapest first, which I believe is the coil, then 02's, then opti. I say do as much research and testing as you possibly can before spending more money than you can by throwing parts at it. These engines are notoriously difficult to find misfires with.
If you check those and all is good, then you start thinking things like opti...
There's a way to test resistance of the coil with a volt meter I think. Do a search here and on camaroz28.com, I know I've read it someplace. May have been on Shoebox's site -
http://shbox.com/page/index.html
Another tip, use factory/AC delco parts as much as humanly possible. People buy coils from their local parts store (who usually don't stock OEM factory parts) and they fail after getting hot from the block.
OPTI TIME... well i saw above you checked the wires but was wondering if you did that buy a visual inspection with the motor off/on? i like to check my wires at night with all the lights off... a bad wire will most certainly throw a very visible spark, usually grounding out on an exhaust manifold, egr valve, face of the block
but unfortunately i believe your opti is crapping the bed. a stock opti with 135K on it... congratulations
At the very least the 02s will give better gas mileage and piece of mind as mentioned above.
