Input shaft play?
I havent even put 1000 miles on the rebuilds and I just pulled it out for the 3rd time.
addressing the front input shaft seal leak, I noticed when I would jerk the shaft in one direction or another It had play of atleast .055 or more(estimateing without a dial indicator)
What causes the shaft litterally to have room for you to wobble it arround? Would this be the culprit of BOTH input shaft seals leaking?
what is considered normal shaft play?
Alot of wobble in the input shaft would indicate the shimming wasn't done properly. This is easy enough to check with the trans out, and a dial-gauge.
If this is on a vette unit , be sure its not the shift rail seal on top leaking , those can give trouble if not properly installed . Also check the cluster gear plug and make sure its not leaking from there either . Its located under the input shaft .
Other than that , leaks from a rebuilt T56 are pretty uncommon .
When I rock the shaft i can litterally see the seal move some..
I wonder if I installed a sleeve on the shaft and a fresh seal if this will fix my issues?
the other bearing beside it had spun perfectly round. When I set the race back on it it didnt seem to be as bad, but again the other bearing did it none at all.
Can I shim it with the front cover off and achieve the proper shimming?
The input bearing has a .036 shim, and the other bearing has a .025 shim
I was looking at it closely with the cover off obviously it has allot of play all the play is moving down in the 4th gear synchro region. How would shimming keep this from happening?
I didnt have any issues in the front 1-4th with the trans other than the leak, So should I leave well enough alone and just replace the seal?
I was playing with the input shaft and I accidently picked it up, I believe it dropped back down where it came out, as that main gear blocked it from being removed, Did I do any harm there before I seal it back up? Is there any special alignent? It seems ok
The seal was installed FLUSH with the bore it goes into, Is this its correct position? I have a new seal to put in and I also have a matco seal intaller kit that put them in smooth and flat.
The side with the spring was facing the outside of the transmission. when its supposed to face the inside. I think I found my smokeing gun.
Theres going to be a longggggggg post about this sponsor when im done.
well sometimes you cant see the forest for the trees
I have been paranoid ever since I got some shoddy work done years ago. I now try and do all my own work.. but at the same time its very dauting and intimidating, to think there might be somethign small im overlooking since I dont do this stuff for a living or daily etc.
If we break something we sure as heck will know it and want to make sure we get it fixed, nothing makes me madder than for someone to break something else while fixing on problem only to try and charge me to fix the other thing they just noticed was broke
Or when you come back after finding some other noise ticking or clunking that wasnt there before and they say oh thatll be another charge to fix that... grr
