Just installed poly tranny mount, not what I expected
Old 10-01-2003 | 05:22 PM
BuckeyeROC's Avatar
King of Pigskin Knowledge
Default Just installed poly tranny mount, not what I expected
Wow! I have ALOT more noise. I did a search and read about it, and even saw a post about the exhaust pulse traveling through the poly mount and into the interior. But I have a poly tranny mount in my IROC, so I didn't think it was a big deal. The IROC has an auto tranny whereas my T/A has a T-56, that must make a HUGE difference. It sounds like the engine is kinda "puttering" now with the pulses coming into the interior.
This thing is loud. I actually looked under the car when I got back from the test drive to make sure the y-pipe didn't move somehow and made sure nothing was loose with the mount and support brace. Everything seems in order. Guess I need to get used to this thing.
Everyone else experience the same thing?
Old 10-01-2003 | 05:47 PM
T/A rocker's Avatar
Default Re: Just installed poly tranny mount, not what I expected
Yeah, same here. I got an ES poly mount, the vibration and noise was too much- feels like you can feel every cylinder pulse. Then I tried the Prothane poly mount. Same thing. Others said it takes time to break in, so I gave it about 3000 miles, it got a little better but again I got tired of it, went back to my 1Le mount.
Old 10-01-2003 | 06:00 PM
BuckeyeROC's Avatar
Did you use that plate that comes w/ it? I didn't b/c I read it makes the noise worse and makes the mount taller than stock and could cause the tranny to sit too high and bump the tunnel.
Old 10-03-2003 | 09:48 AM
trackbird's Avatar
You may still be bumping the tunnel under acceleration (crossmember flex), you may want to verify your clearance between the trans and trans tunnel. It may take a couple washers to get the space you need (just watch your driveshaft angles!).
Just my thoughts....
Old 10-03-2003 | 10:18 AM
WILWAXU's Avatar
I shaved the "preload" bumps off. Helped alot, but it's still very stiff.
Old 10-03-2003 | 03:45 PM
BuckeyeROC's Avatar
Thanks for the input guys. I don't think it's hitting the tunnel at all, I ran it hard a couple times last night. The noise comes in at about 2500 or so rpm and it kind of resonates.
So you think the shaft angle and/or noise would be better w/ the preload bumps off?
Old 10-04-2003 | 11:59 PM
trackbird's Avatar
I'd measure the distance from the crossmember to the mounting pad on the stock mount and make the energy suspension "match" that distance. If the energy suspension mount is 1/4 inch taller, space the crossmember down 1/4 inch and that may cure any geometry problems. After that, it will be a matter of the difference in materials between the poly and the stock mount.
Old 10-05-2003 | 01:17 AM
14u2nv's Avatar
You can swap the poly mount for a 1LE mount if you want to. The 1LE mount is stiffer then the OEM mount but not as bad as the poly unit.
Old 10-06-2003 | 02:22 PM
WILWAXU's Avatar
The 01-02 cars have the 1LE as the standard mount.
Old 10-06-2003 | 03:32 PM
trackbird's Avatar
Really?
Old 10-06-2003 | 09:38 PM
14u2nv's Avatar
Well his is a 98, whats the difference if a 01-02 has the 1LE mount too.
Old 10-07-2003 | 11:30 AM
NHRATA01's Avatar
This true? I might've just wasted my money on a Prothane mount
Old 10-07-2003 | 01:28 PM
Sniper33's Avatar
It was only $23!! LOL
Old 10-07-2003 | 02:50 PM
NHRATA01's Avatar
Hey thats 23 more bucks to my Buy a 12 bolt fund!
Old 10-07-2003 | 03:08 PM
Sniper33's Avatar
Oh you have one of those fund too?! That makes two of us! I also see your a Cartek customer, very nice!
Old 10-07-2003 | 07:46 PM
BuckeyeROC's Avatar
I think anyone that owns an f-body and starts modding it has a 12 bolt fund
My problem is, I have 2 f-bods w/ stock 10 bolts, I don't even want to spend $2200+ on 1 rear, let alone 2. So I'm going to have to make a decision sometime soon on which car to keep. The IROC should be in the high 10's next year w/ the 150 shot and tuning, but I'd like to get the Trans Am up over the 450 rwhp N/A mark too. Why couldn't GM just give us something like the Ford 8.8?
Old 10-07-2003 | 10:27 PM
trackbird's Avatar
I have a 2002.....easy enough....
Old 10-08-2003 | 08:28 AM
01 SS Jay's Avatar
My 01 stock mount feels sloppy as hell. I cant imagine that its a 1LE piece. Taking off my shifter jumps easily 3/4".
Old 10-08-2003 | 09:17 AM
NHRATA01's Avatar
Well I'll update...I just had a Spec 3 put in by Eastside yesterday and had them throw in the Prothane trans mount. Its really not that bad compared to what I was expecting - especially after having ridden in a Cavalier with a poly trans mount (i know, Jbody != Fbody). Anyways there's only slightly more vibration noticed at idle, which is expected with a lope happy came like a T1. Driving around doesn't feel much different. The biggest difference is at startup and shutdown, the car shakes alot more for that brief second or 2 when the motor is first fireing. At least now I should never have to worry about ripping this thing up with a hard shift.
