Pilot bearing Puller Help!
Anyone know of a good pilot bearing puller I could get? and where to buy or order one that with fit ls1 size pilot bearings.
I have a slide hammer type pilot bearing puller and its not doing anything, it hasnt moved one bit. I think I just need a good screw type puller anybody know of anything? I know OTC makes a good one but which part # is it 7318 or 7319 ? cause they have 2 of them and i dont know which one will work with our type pilot bearing.
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
The slide puller didn't budge it for me either. I ended up dremeling the crap out of it and then using a chisel to crack it.
In retrospect I wonder if you banged the bearing in just a little with a chisel or whatever if then it would be loose enough for the slide puller to work.
I added a picture of a nice looking puller in this thread over here:
https://ls1tech.com/forums/manual-tr...al-issues.html
I have a really good one I bought from Mac quite a few years back. Not sure they still offer it? I'll find the number I know it's on the box maybe you can still buy one? I will post it tomorrow when I can. Bob
Use a loaf of white bread, keep stuffing it in there with your clutch algnment tool(might have to trim the round thing off the end of it) and just keep stuffing it in there, use a hammer if need be. and just keep stuffing peices in there, and bam, it will start to come out!
I swear on it. I have done it this way about 15 times! works perfect EVERYTIME!!!
bad idea.....
