F-body & CTS T56 differences
Old Jan 20, 2009 | 06:53 PM
QUICKQTR's Avatar
Default F-body & CTS T56 differences
What are the main differences in the F-body & CTS T56 transmissions? Does the CTS use a torque arm also? Is the torque arm required if I am putting this into another type of vehicle?
Old Jan 20, 2009 | 07:18 PM
thesource's Avatar
Its completely different than the F body unit .
Old Jan 20, 2009 | 09:37 PM
QUICKQTR's Avatar
How are they different?
Old Jan 20, 2009 | 09:44 PM
thesource's Avatar
I don't have a file picture of the CTS-V units we've built but I am pretty sure no other T56 based unit is like it .
Old Jan 20, 2009 | 10:16 PM
QUICKQTR's Avatar
So I assume the Cad unit will probably not be a good candidate for my conversion?
Thank you for the info...I was getting rdy to buy one this weekend!
Old Jan 21, 2009 | 06:56 AM
85MikeTPI's Avatar
CTS-V dimensions
I've converted one over to a F-body unit, but it's not cheap nor for the faint of heart. (No yoke, 3-bolt flange, remote shifter, etc.)
https://ls1tech.com/forums/lsx-parts...pro-parts.html
Old Jan 21, 2009 | 07:36 AM
QUICKQTR's Avatar
Thank you for the dimensional pics, that is kinda what I was hoping to find for starters.
Why did you use the Cad tranny? When compared to the F-body: Same clutch & pressure plate? Are the pedal/hydraulic set-ups the same? I am assuming they bolt up to the LS-series without any changes...I have no driveline parts as of yet, so I am starting with a clean slate. I am just trying to see what all of my options are before I fork out the money to buy one. (I was wondering what the 3-bolt flange was for when I saw a pic of one- thought it was a plug they were using)
Old Jan 21, 2009 | 08:26 AM
85MikeTPI's Avatar
The CTS-V trans was picked up for cheap, which is why I did the conversion. If you can't get one for less than $400, it might not be worth it.
The CTS-V was behind the LS6, so the clutch setup has to be aware of that,
(extended pilot, slave, etc.) but many LS1/LS6 adaptations have been documented.
Basically you'll need:
- GTO mainshaft
- fbody tail housing
- fbody shift rail
- misc fbody detent/offset/VSS reluctor/detent cover/detent guide/sensors/shifter/etc.
mike
