parts for ls7 clutch
Ok what parts can you use with a ls7 clutch kit like can a stock ls1 pilot bearing work also for the throwout beairng which one would work would a stock ls1 one work or would you need a different one And where can i but one at? And one last question whats a good master cylinder to get?
SDPC they are a sponsor here with an awesome ls7 clutch kit you can buy the pilot bearing and slave cylinder/throw out bearing from them great prices great product... as far as master cylinder depends on what you want i like my adjustable tick performance has great adjustables i hear and yes your stock master will work but take into consideration how many miles are on the car
i just put in an ls7 clutch in my 2000 t/a. you will need an ls2 flywheel for the clutch and thats it. i didnt change out my stock pilot bearing or master cylinder. i did get a stock ls1 slave/ throwout bearing.
i know this thread is a few wks old but same topic. i just fried my pressure plate friday night. im going with the ls7 clutch kit. is there anything else i should get while this is getting done?i already have a new tick master adj.
list for 2000 ss
new ls7 clutch kit
new gm 01-02 slave
new pilot bearing
what is a throw out bearing?
anything else i'm missing?
list for 2000 ss
new ls7 clutch kit
new gm 01-02 slave
new pilot bearing
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Location: Your girl's back door giving her the long stroke while you're at work
The throwout bearing is going to be on the slave cylinder when you order it. You pretty much got everything covered.
FYI: My CETA went 7.01 @103( 1.71 60ft) and a 11.15 @ 129(1.91 60ft) with a LS7 clutch. Heads, cam, full exhaust, FAST 90/90, full bolt-ons with a 150 shot. Never had a single issue with the clutch.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Can anyone explain why a LS7 Pressure plate requires an LS2 flywheel? LS1 will not work??? Is the bolt pattern different, or is there a recess in the LS2 flywheel so the height is different?
