Bad/Nothcy Shifts
Whenever I change gears in my car it takes a decent amount of effort and usually feels like it's catching a few teeth on the gears. Its definitely not smooth like my last trans was. I checked the clutch to make sure its releasing all the way and it is but every gear has this problem. If it was just one or two gears I would think I just needed to replace a synchro or something but its every gear. Any ideas on how to fix this?
I put the back of the car up on jackstands so that the rear tires weren't touching the ground. Then I stuck it in first and with the clutch depressed all the way I revved the motor up to 6k several times and the rear tires didn't budge. Also, I have a Tick master and a new slave in there so I don't think its a hydraulic issue.
I changed my fluid at about 80,000 miles just to be safe. I had a friend change it at where he worked and used the cheap stuff they had on hand ( I think it was pennzoil or something). Ever since it has been notchy as a ****. Also, when downshifting to first I can hear a whirring sound at anything above 15MPH. All this started happening when the fluid was changed. I think I will be changing it soon to something better.
It definitely shifts the roughest when its really cold but it still does it when its warm. I'm running some cheapo dex III in it right now and its always worked pretty well for me. I got it from a guy that pulled it out of his GTO at 30k miles. He said it shifted great when he pulled it out. I guess I might try changing out the fluid but I really don't think that'll fix it. The thing really just shifts like crap.
I've already got a pilot bushing instead of a pilot bearing. If the bearing were bad and the input shaft was seized to the crank I wouldn't be able to shift let alone start the car without it trying to take off on me.
