How to install a shifter?
Old Feb 12, 2009 | 03:30 PM
Konstantine16's Avatar
Default How to install a shifter?
Just got my new MGW shortshifter in the mail today for my t56 in my trans am. Replacing the stock hurst with it. Did a search on google and ls1tech and found no write-ups on the procedure for removing and installing a new one.
If you could give me some guidance on this I would greatly appreciate it.
Old Feb 12, 2009 | 09:21 PM
HavATampa's Avatar
Nice choice on shifters! Here you go:
Install University - Shifter Install
Old Feb 13, 2009 | 01:00 PM
sdm1234's Avatar
Before installing it, read up on this thread I started from a while back. It goes over the noise problem and how I did an easy fix. Good luck and enjoy!
https://ls1tech.com/forums/manual-tr...llet-plus.html
Old Feb 13, 2009 | 01:06 PM
bballr4567's Avatar
You dont need to go through that process with the MGW. It replaces what you replaced. Just put your #6 boot back in the car as the tranny noise is amazingly loud without it.
You'll love the shifter and beat yourself for not buying it sooner.
Old Feb 13, 2009 | 01:35 PM
93batmobile's Avatar
I just put my MGW in yesterday. The way i did the #6 boot is i cut out a small section on the top of the boot and slide it down over the main section of the shifter and had the mgw boot come up through it. looks a bit nicer too. You will definitely be happy with this shifter though
Old Feb 13, 2009 | 07:54 PM
Yeah I installed it today, its really nice, makes the 2-3 shift alot easier. I have to say I'm getting alot of noise though, probably because of my #6 boot not fitting easily, oh well, I just crank the music anyway...
Old Feb 13, 2009 | 09:02 PM
HavATampa's Avatar
Thumbs up
#6 boot installed properly on the MGW shifter.
Old Feb 13, 2009 | 11:23 PM
bballr4567's Avatar
I put mine ALL the way over the gold/yellow part. It shifts perfectly fine and actually doesnt even rub the center console.
Taken from MeentSS02's thread here.
https://ls1tech.com/forums/manual-tr...-shifters.html
Old Feb 13, 2009 | 11:46 PM
HavATampa's Avatar
It's just uglier that way.
Old Feb 14, 2009 | 12:41 AM
haha i tried to cut mine and make it look clean like yours but i failed miserably. Oh well not too many people are gonna be down there checkin it out anyways. That is the first time i have heard of noise issues with this shifter though
Old Feb 14, 2009 | 04:15 PM
bballr4567's Avatar
Nobody said anything about the shifter. If you take of the #6 boot with the stock shifter you can hear the tranny churning around down there.
The shifter is DEAD quiet. In fact its probably quieter than the stock Hurst.
Old Feb 16, 2009 | 08:43 PM
Yeah its the tranny im hearing, I have the #6 boot put on the shifter incorrectly I think comparing it to the pics you both posted up, I have it all the way up to the orange part past the rubber on the shifter so its probably not making a good seal
Old Feb 16, 2009 | 11:47 PM
bballr4567's Avatar
Well if you are hearing the tranny that much WITH the #6 boot on you might want to check the seal with the actual shifter. If that has backed off some you might want to put some more RTV on it and retighten down the shifter bolts.
Also make sure you got all your bolts for the boot are on as well. I missed one and it still let in A LOT of noise as well.
Old Feb 17, 2009 | 02:48 PM
99T/A_Marine's Avatar
Ditto.
Old Feb 18, 2009 | 07:18 PM
stangslayer98's Avatar
where did you guys buy the shifter I did a brief search and only found shifter's for mustangs
Old Feb 18, 2009 | 07:20 PM
bballr4567's Avatar
You HAVE to call MGW to order it. The website hasnt been updated in ages. They do sell it though. Took approx 4 minutes to order it over the phone and was here two days later.
Old Feb 18, 2009 | 07:30 PM
HavATampa's Avatar
Yup, what he ^ said!
Old Apr 15, 2009 | 05:52 PM
1999Z28's Avatar
Why do you guys call it the #6 boot?
Old Apr 15, 2009 | 05:54 PM
bballr4567's Avatar
There is a #6 on it.
Seriously. There is a literally a 6 on it.
Old Apr 15, 2009 | 09:54 PM
HavATampa's Avatar
What ^he^ said...top left corner of the rubber boot has a big 6 stamped on it from the factory. (Big Red Arrow Not A GM Part)
