Need help???
Old Feb 14, 2009 | 07:20 PM
2000CAMARO_SS's Avatar
Default Need help???
alright i just got a stage 2 clutch put in my car and now when i drive it i cant go into 2nd,3rd or 5th they told me to get the specs on the skip **** so the mechanic could make it is this true or is it some thing else???
Old Feb 14, 2009 | 07:33 PM
HavATampa's Avatar
heh...you said skip ****. Did your skip "shift" stuff work before the clutch? There is a skip shift feature on these cars that can be disabled either by a tune or you can buy a small device to plug in by the tranny. Could he have possibly disconnected yours when he took the tranny out? You can drive like a grandma though and disable it to test if it lets you go in all gears. I didn't think it blocked 5th gear though.
Old Feb 14, 2009 | 07:51 PM
yea the skip shift worked...and yea its connected...and this is only when the car is on when its off i can go threw all 6 gears
Old Feb 15, 2009 | 08:29 AM
Gen414's Avatar
The skip shift has nothing to do with 5th. WHAT is your mechanic wanting to make?
That being said, you have a new clutch, and it will NOT go into 2nd, 3rd or 5th? Right? Will it go into Reverse, 1st, 4th and 6th OK?
Old Feb 15, 2009 | 10:37 AM
wrencher's Avatar
wrencher
Do you have an aftermarket adjustable shifter?
Are the stops out too far keeping you from engaging the affected gears?
Old Feb 15, 2009 | 12:15 PM
i do have a b and m short shifter but its sitting right
Old Feb 15, 2009 | 12:17 PM
idk he wanted to make the skip shift deal i gess
Old Feb 15, 2009 | 04:37 PM
wrencher's Avatar
wrencher
At the base of a B&M there are stops that are adjustable. If they are out too far they can cause problems getting into gear.
Old Feb 16, 2009 | 04:28 PM
this only happens when the car is on when it is off i could go into all 7 gears so im gessing its an electrical problem
