Viper t56 6 speed conversion info needed please
Hello to everyone I am sure some body else has asked this question in the past but here it goes I bought a used 2005 viper 6 speed t56 and am wanting to install it in my 2000 m6 Camaro I don't know what is needed or who make the parts required any help is greatly appreciated thanks all
KB
KB
You need to machine the input shaft. (Cost me $65 locally)
You need to use a viper slave, with a Fbody quick-connect (or convert the front plate)
You need to enlarge your shifter hole in the floor/tunnel, to move it forward ~2 inches.
You need to use a viper/T5/cobra square mount shifter
unless you want to convert to an LS1 tailhousing, then it has to be bored, fit with a larger bushing, cut the mainshaft shorter, and replace the shift linkage rod.
The viper VSS is 11 tooth (Fbody = 17t), so you'll have to reprogram the ECM.
I did this conversion, and 85MikeTPI was a big part of it, and hit the nail on teh head. If you do a search on this site, you will find all kinds of links that will take you here and there in giving you pics and very detailed info.
If you do a tailhousing conversion, you'll be using a GM pickup. It's just generalized FYI to the poster anyway, since some late-model viper/ram T56s didn't even have a VSS/reluctor on the trans.
you should of just converted over your trans way less bullshit
sorry just my 2 cents
see if you can just get a camaro tailhousing thats already done like something from D@D it might save some time and money
