Best 60's: M6-10bolt
Old 02-25-2009, 03:10 PM
  #41
NSSANE02's Avatar
Originally Posted by aggie-chase
Were any of you guys running without a front sway bar? I am thinking about taking mine off before I go to the track Saturday, but haven't decided yet.
One of the first things I did, didn't really notice a difference though.
Old 02-25-2009, 07:09 PM
  #42
FMX05's Avatar
Update: Went to the track last weekend and ran a new personal best of 11.92@119.2with a 1.81 60'. I held the revs at 5k and slipped it very quickly on BFG DR's. Still stock 101k mile suspension with bilstein shocks. Full weight. I tried leaving harder on the next run but blew the tires off. I think I got them too hot.
On a side note, I am in the process of changing my true duals over to 3"x12" bullets and went to the track with an open X-pipe. With dumped 2.5" powersticks I ran 12.2x-12.3x@115.x 5 passes in a row. With the open X I ran 11.92@119.2 and followed it up with 2 a 12.0x@118.8 and a 12.1x@118.x (spun off the line).
4mph from an apparently restricted exhaust? Weather conditions were almost identical. 60' was within .06
Old 02-25-2009, 07:19 PM
  #43
78novacaine's Avatar
1.7x on street tires and stock suspension, (ran 12.23 @ 113 with full exhaust and lid, untuned, on that one pass, normally run 12.8x-13.x) but it was a fluke pass, but i have managed a few 1.9x and one 1.8x on street tires as well
Old 02-25-2009, 07:56 PM
  #44
NSSANE02's Avatar
That's badass man. I would love to see a video of a car on street tires pull that kind of 60'... especially with a stock suspension, just awesome. What track was that?
Old 02-25-2009, 07:57 PM
  #45
at HRP, like i said, the 1.7x was a fluke, but the car does usually consistently 60 in the 1.9x range, and hooks up VERY well on the street
Old 02-26-2009, 03:37 PM
  #46
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Still had mine hooked up
Old 02-26-2009, 09:57 PM
  #47
BarneyMobile's Avatar
1.74 slipping the clutch. That was on M/T drag radials and a Spec 3+ w/ a Fidanza aluminum flywheel. Over the winter I installed a 9" and I just got some 17x11.5 Hoosier QTP's. Now Im just gonna drop the clutch and hope for the best.
Old 02-27-2009, 12:42 PM
  #48
flintwrench69's Avatar
Originally Posted by airforcemanss
ive read about launching an m6 an will have more practice this season with my new ls7 clutch going in and tickmaster adj i already have. what does "slipping the clutch" mean.does that mean keeping your foot on the clutch and then letting off or "feathering it off" at 4k rpm launches? i also can't figure out side stepping? sorry for the newb questions but i will be doing a lot of practice at the strip this season.
Yea, slipping the clutch is feathering the clutch pedal. You dont want to side step it, get a line lock instead.
Old 02-27-2009, 01:07 PM
  #49
pitbull14218's Avatar
What does side steping the clutch even mean? Is it dumping the clutch?
Old 02-27-2009, 03:09 PM
  #50
aggie-chase's Avatar
yes. its just moving your foot of the pedal and having it instantly engage.
Old 02-27-2009, 03:19 PM
  #51
slow ride 02's Avatar
Can you guys help me? The best I have done with Nitto D/R's 2.1 60' and most of the time it's 2.2 & 2.3. That sucks!!! I would like some 1.6 to 1.7 60' times.
Old 02-27-2009, 06:32 PM
  #52
wickedrx7's Avatar
What clutch are you running? What are you launching at? How are you launching......slipping it or just popping it out?
Old 02-27-2009, 07:15 PM
  #53
NSSANE02's Avatar
What does a line lock have to do with launching?
Old 02-27-2009, 07:21 PM
  #54
NSSANE02's Avatar
That's not going to be easy with nittos. Either way, feather it just enough to keep it stuck to the ground. It also keeps it higher in the power band.
Quick Reply: Best 60's: M6-10bolt
