Tick Speedbleeder leaking not into slave
any one have there Tick Speedbleeder leaking between the bleeder coupling and the line end. not the end that goes into the slave. shown in pic. anyone have this problem i just installed it
LS1TECH Sponsor
If you will tighten the bleeder down completely there won't be a leak there. There will be some minor leakage there during the bleed process only...its is a flaw that was brought to our attention just recently. It leaks because the fitting swivels once cracked loose....we're working on a solution for that right now, but for everyone that has the line it will still function as a remote bleeder.
ok ill try it thanks jonathan i got like 2 more turn then its maxed out ill try it ill let you know what happens. 99ls6ss i put a new clutch slave master
