Slave connector wont go back in.. Why??
Old 10-22-2003 | 12:47 AM
LIL SS's Avatar
Moderator
Default Slave connector wont go back in.. Why??
Been trying to push the friggin thing in for like a half hour. Does not want to seat. Any suggestions?
Old 10-22-2003 | 01:26 AM
kp's Avatar
kp
Default Re: Slave connector wont go back in.. Why??
open the bleeder then snap it in
Old 10-22-2003 | 01:50 AM
LIL SS's Avatar
Moderator
How do you reach the bleader?? Dumb question I know..
Old 10-22-2003 | 02:52 AM
Jason99T/A's Avatar
I can shift faster than you.
1/4" drive ratchet with a 7/16" socket. Put the socket on the bleeder screw first and the put the ratchet on. Open the bleeder and then push in the connector. Then, close the bleeder screw.
Jason99T/A's Avatar
The bleeder screw is located just above where the braided line connects to the slave cyl.
Old 10-22-2003 | 11:37 AM
LIL SS's Avatar
Moderator
Thanks guys.. I will be doing this when I get home.. Then put the Y-pipe in and time to go break it in..
Old 10-22-2003 | 12:57 PM
Camaroholic's Avatar
I bought a 3/8" breaker bar (small one) at AutoZone to do the bleeding of the slave.
The problem with using a ratchet is that they normally go one direction or the other (tighten or loosen), but not both.
Plus the tranny tunnel clearance getting at the bleeder valve isn't all that great with your average ratchet either...
FWIW.
Andrew
Old 10-22-2003 | 01:42 PM
kp's Avatar
kp
Think you meant 1/4 inch breaker bar
I use a craftsman 1/4" breaker bar and short 7/16" socket. I'm sure any 1/4" breaker bar will work - its a pain using a ratchet..
Old 10-22-2003 | 02:38 PM
No, I meant 3/8". It's not very big tho (it's a relatively short, low profile one).
It's definitely not 1/2", and it's definitely not 1/4"... :p
-Andrew
Old 10-22-2003 | 03:52 PM
kp's Avatar
kp
Still more room with the 1/4"
My 3/8 breaker bar is huge, I have a hard time getting the 1/4" one in there on my car. Sometimes I think of just drilling a hole in the tunnel right neaxt to that thing so I can bleed it while sitting in the car
Old 10-22-2003 | 08:41 PM
Believe me, I've had the same thought about drilling a hole. But, I finally found a car related activity that my wife and I can do together!
"OK, pump the pedal in"... "OK, let it out"... "OK, push it in"...
Andrew
