Manual Transmission Oil
Old 03-31-2009, 08:54 AM
Animal323's Avatar
Default Manual Transmission Oil
What kind of oil do i use? i have a 02 trans am ws6 probably doesnt matter but what do i use? Manual says Dexron III for automatic transmissions but doesnt say anything for a manual.
Old 03-31-2009, 09:33 AM
Internet Mechanic
BlackScreaminMachine's Avatar
https://ls1tech.com/forums/manual-tr...omesh-not.html
See my post, should be #11.
You can use ATF (DexonIII or whatever Dexron that is out there now), Mobile 1 ATF, and I use Pennzoil Synchromesh which is the same as GM Syncromesh which is avalible at auto parts stores.
Old 03-31-2009, 09:39 AM
puggerton03's Avatar
dextron III. trust me i put synthetic in my 02 z28 6-speed and it didnt shift as good. i changed it back to dextron III after about 500 miles.
Old 03-31-2009, 09:43 AM
deelong4002's Avatar
it says dextron III on the case if you crawl under.
Old 03-31-2009, 09:49 AM
Internet Mechanic
What Synthetic fluid??
Royal Purple?
Redline?
Old 03-31-2009, 09:51 AM
i want to say it was mobil 1 synthetic tranny fluid.
Old 03-31-2009, 08:15 PM
Animal323's Avatar
Blackscreamin from what i read in the other post it looks like your rite but is the penzoil a type of dextron or whats the diffrence between dextron and atf if someone can help me?
Old 03-31-2009, 08:18 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
YUP--Keep it the same......that is the best....they would not put in crap so they would get warranty work.
T/AWS666's Avatar
GM Syncromesh works great!!!
Old 03-31-2009, 08:21 PM
Animal323's Avatar
so you guys run it is there a shift diffrence what i mean like smoother shifts in and outta gears. When i shift into first it wont go sometimes then i gotta rock it back and forth then get it in gear or it has trouble sometimes going into gears.
Old 03-31-2009, 08:43 PM
fatdave's Avatar
If I remember right there was a issue with Royal Purple's synthetic ATF eating blocker rings out in the T56. I think it was Six Speed INC that had said something like that, maybe someone else can chime in on this.
Old 03-31-2009, 08:44 PM
Animal323's Avatar
i was looking at the royal purple until i found out about this penzoil synchromesh
Old 03-31-2009, 08:54 PM
Animal323's Avatar
http://www.chevyhiperformance.com/te.../photo_14.html
this is what i was looking at
Old 04-01-2009, 08:12 AM
Internet Mechanic
Yup, many posts and a buddy who got a GTO trans from them. No RP due to eating up the blocker rings and they would not warrentee if you used it.
Old 04-01-2009, 08:13 AM
Internet Mechanic
What I can tell you is in CT we can get REAL cold and REAL hot. When the fluid is at or below freezing the trans has a slight grind (i can feel it resisting) on the 2-3 shift before the tick master cyl. I put in the Synchromesh and it goes away and when the trans is up to temp, it shifts near redline like it should. Like it was ment to be shifted in this manner and its like butter.
Old 04-01-2009, 08:20 AM
ghettocruiser's Avatar
Just to stir the pot... I just switched from Pennzoil Syncromesh to Castrol Dex III yesterday. Havent driven it yet...and the Pennzoil looked super clean still. But Im just trying to different things to see how it reacts.
The Syncro seemed thicker. Even the slightly older and still warm fluid that I took out. Im wondering if its heavy enough to slow things down JUST enough to make shifting notchy. I dont have shifting problems really....just notchy.
I havent had Dex in the trans since I first did the swap...and that was with cruddy Spec clutch and old hydraulics. So this will be a true difference test for me.
J.
Old 04-01-2009, 08:32 AM
Internet Mechanic
J.
Go to my link at the top of the page and then click the links on the Pennzoil data, it did show Synchromesh to be heavier in weight and viscosity. The their ATF.
Old 04-01-2009, 11:00 AM
slayerized6's Avatar
i put in Pennzoil synchromesh 2 weeks ago. defintly have smoother shifting between the gears now
Old 04-01-2009, 03:24 PM
Animal323's Avatar
Thats it im gunna call the dealer and if he says i can use the penzoil ill get it and have it done that night. Everyone using synchromesh in the t56 is doing ok? no one had any issues yet?
Old 04-02-2009, 02:25 PM
PewterScreaminMach's Avatar
Regarding this, I got my beefed up MN12 trans from Six Speeds Inc while my brother rebuilt his on his own with OEM parts. He put Royal Purple in his and I didn't specifically because they told me not to. Long story short, I still lost a blocker ring after not so many miles - most likely due to a disengagement issue - and my brother's has been running strong with him beating the hell out of it power shifting on the street and at the track for almost 20,000 miles. He's also shifts faster than anyone I've ever seen in real life or in a video and his car makes awesome power for the mods.
There is now Royal Purple in my newly rebuilt transmission (rebuilt by my brother and myself).
Quick Reply: Manual Transmission Oil
