Installed Tick Master and now....
What Clutch and what Level?
If a higher level clutch, could just be some NORMAL chatter that you can get from time to time. So, answer that, and let's go from there...
Hmm, hard to really understand what is going on.
Does NOT sound like a clutch problem though. You are saying with teh clutch pedal all teh way out (released) and driving down teh road, is when the pedal is vibrating?
Well, I would say that you installed it (MC) incorrectly, and left the linkage loose, BUT, you say you installed teh MC @ 2 months ago, right?
Well, MAYBE something came loose...check linkage up under dash....for binding/interference, etc...
Yes, while driving down the road and I rest my foot on the clutch, riding the clutch if you will, is when I feel the vibration (and I don't ride the clutch at all, just playing with it this way to feel the vibration). When the car is at a stop in neutral and I rev the car the peddles pulses as well. Should I try bleeding it again? It feels weird when the car is running, but when it is off it feels just like it should.
I appreciate the help!
Ahhh, OK. Well, that being teh case, does sound like a clutch problem (or maybe even a pilot bearing) really can't take to much for granted, or assume anything. Let me ask you this...when you installed the clutch 2 months ago, did you put in a new pilot beariing? If not, do you know how old it is? If you have a bad PB, input shaft could be walking around, causing a vibration as well...
Again, can't overlook anything....
Gen414, I had a shop install the clutch, hence the not stock replacement clutch being in there. I am pretty sure they installed a new pilot bearing as well. Said that everything was new.
Would bleeding the master again be worth the effort? Would that even cause these problems? If not I am taking it back to the shop that installed the clutch. Thanks for all the help guys.
As was mentioned, the pressure plate bolts could have come loose. There should be no vibration in the clutch pedal like you are describing if the clutch assembly is in good working condition. I would take it back to the shop and see if they can find out what the issue is.
I adjusted one of our masters out farther than it should have been one time just to see how the pp would react/feel. You can actually tell the point where the pp has been released as much as it wants to go...the feel of the pedal would change just before the pedal hit the floor. It would get hard and just didn't feel right...its tough to explain. If you follow our instructions and adjust it out in small increments you should never have anything to worry about.
My money is on loose pressure plate bolts, but if not it will be the pressure plate itself. Something is going on with the fingers of the pressure plate not being even all the way around, which is translated as a pulsation back through the tob, slave, and up to the pedal. A couple of lose bolts will make the fingers uneven, but if you get the tranny out and all the bolts are still torqued but the fingers aren't even then you will know its a faulty pressure plate.
Also, how far out is too far as far as the peddle goes? Mine is probably even with the brake peddle.
Thanks for the help.
