t56 in ls1 GTO?
Old 10-22-2009, 03:22 PM
uphigh07's Avatar
Default t56 in ls1 GTO?
ok guys i have a fully built t56 out of an 02 trans am and was wondering if this would work in a LS1 GTO i no the ratios are not the same but will everything bolt up. Whats the difference?
Do i just use the GTO bell housing instead of the trans am bell housing?
any help would be great!
Old 10-22-2009, 03:56 PM
bearcatt's Avatar
Yes the GTO bellhousing is good to go and you will need the GTO shiftcup.
Old 10-22-2009, 05:35 PM
uphigh07's Avatar
ok well i have both setups but the tranny in the gto is haveing problems so since i have this other t56 out of an ls1 ta i was just making sure everything would swap over.
Old 10-22-2009, 06:06 PM
bearcatt's Avatar
One more thing is the hydraulic slave connection for the GTO will be needed as well.
Old 10-22-2009, 06:35 PM
uphigh07's Avatar
ok thanks bud
Old 10-22-2009, 09:38 PM
hivoltagedriver's Avatar
Just the fittings on the slave are different. The slave is the same.
Old 10-22-2009, 11:13 PM
bearcatt's Avatar
Glad to help. You're good to go.
Old 10-23-2009, 02:07 AM
uphigh07's Avatar
ok thanks guys for the help
Quick Reply: t56 in ls1 GTO?
