Out with the Spec and in with ??
I picked up some LT headers and a new cam awhile back and am getting ready to put them in this winter. While I'm at that I am going to pull the tranny and install a new clutch. I currently have a Spec stage 3 in the car and absolutely hate it. It squeals, shudders, and royally pisses me off. Looking back there is now reason I should of even bought that type of clutch as my car is fairly stock but live and learn I guess.
So I'm looking for some recommendations on a new clutch for a daily driver with headers and cam. I do not plan on modding the car any more than that so I don't need some super heavy duty clutch for 500+ hp.
So here are the questions.
1. Good daily driver clutch setup/ what has worked for you? Price?
2. Do I really need a new flywheel? aluminum or steel?
3. While I have this stuff apart is there anything else worth doing?
4. Any other advice?
My car will probably only go to the drag strip once a year and maybe an autocross event or two a summer.
I did do some searching for old threads and will again when I get more time but if you want to link some that pertain to my situation that would be great too.
Thanks guys!
I have this in my car and pound for pound has taken the abuse and held up perfectly. I mated it to a Tick Perf. Master Cyl and have never looked back.
The whole set up is like $1,000 + Cost of Master Cyl and if smart a new slave and pilot bearing. The kit comes with a new Flywheel, and is considered smart to buy it matched. As Stated when it is apart, you put in a new Slave and regular Clutch master as well as pilot bearing.
This clutch, you can slip it like stock and it takes it.
There are Monster Clutches out there, I have not used them but I think that there is a core group here that will talk them up so get some of their experiences too.
If you want a clutch that performs like stock, you'll need to go with a stock-type clutch. That includes the clamp load of the pressure plate and friction material on the disk.
I've personally driven an LS7 clutch that was in a heads/cam Formula, and it held that power with no problems, and the dude drove the hell out of that car. As long as you don't hot lap it at the drag strip, it should last a long time.
Is the aluminum flywheel worth the extra money?
Do I really need a new slave or master?
I wasn't really looking to do this project at all and don't want to throw uneccessary money at it but I also don't want to be to cheap and not change something while I have it all apart. I'd rather do it right the first time.
Thanks for the input guys!
New master? Probably not.
New slave? It depends - but at the very least, I'd replace the throwout bearing. The last time I priced a throwout bearing, the cost was damn near what the entire slave cylinder assmebly was, which comes with a brand new throwout bearing. This one is up to you - if a master cylinder goes out, you don't have to drop the transmission to fix it. If the slave goes out, you'll be dropping the transmission (again).
If I were you, I'd give Spec a call. The clutch you went with was way too aggressive for you...just like any other clutch company, they have less aggressive options, and their support on here is good. People just need to be realistic about their intended power goals and their tolerance for shitty driveability. You can't honestly expect a puck-style clutch to drive even remotely similar to a full-faced design.
I don't blame Spec at all. I just didn't know what I was getting into at the the time with a pucked disc(young/dumb). So if my plate and flywheel are still good I can possibly just replace the pucked disc with a full face one? I'll try to dig up where I got it from but it's been a few years already.
Thanks
Found it!
Thank god for old threads. Looks like I ordered from LM performance (I think they are a sponsor here) in July of 2004. I probably have about 40,000 miles on this clutch. I may start my project this weekend and could have the clutch out to measure whatever is needed. Pretty old so hopefully you guys would still have something that would work.....that is if my parts are still good.Thanks again!
Thanks for all the other input too guys!
I think I will probably go with a whole new setup just to be safe. Looking for something with good street manners and long life. The car might see the track once every year or two.
Looks like the best options could be:
Spec Stage 2
Monster Stage 2
LS7
I'm going to see if I can add a poll to the original post. Recommendations on who has the best price and/or service is appreciated. Thanks.
Ok just got the numbers back from my machine shop at work. I wanted a sanity check after I got my figures this morning.
Disc is .288 - .292
Plate is .015 out of flat
Flywheel is .008 out of flat
So basically disc and plate are junk and flywheel could be turned down .01 and re-used if I wanted?
Thanks.
