Best fluid to use
Old 03-25-2010, 12:55 AM
my95LTwon's Avatar
Default Best fluid to use
I'm just curious if anyone has any preference for the trans fluid they use? I want to change my fluid this weekend before I get her back on the road and I'm just curious if any kind is better than another. I have heard that Honda ATF is supposed to be pretty nice, but I just want to see what info you guys have to offer. Thanks!
Old 03-25-2010, 01:03 AM
bigj2717's Avatar
Either use a good synthetic ATF or use regular gm Dexron 3 like it say on the side of the trans
Old 03-25-2010, 11:08 AM
tx3
tx3's Avatar
Tick Performance recommends just any dex 3.. I have synchromesh in mine now. Very nice in the warm weather, but a little notchy in the cold at startup.. Gonna flush and put dex 3 in and see how that performs.
Old 03-25-2010, 08:08 PM
studderin's Avatar
normal, store brand ATF
Old 03-26-2010, 01:05 AM
my95LTwon's Avatar
Sooooo, I guess I'm just looking for the cheapest dextron 3? Doesnt really matter? I guess thats easy enough. thanks
Old 03-26-2010, 04:59 AM
johnnybravo's Avatar
I put in Castrol Dexron/Mercon. Says it's for Dexron III applications. Got it cheap at Autozone. Put it in at about 50,000 miles on the car. The trans did shift noticeably smoother.
Old 03-26-2010, 05:21 AM
nighthawk15's Avatar
Pretty much, man. The thing with a manual transmission running ATF is that really ANY ATF is total overkill. A manual never heats up enough to break down ATF, which is why manual F-bodys have no trans fluid change intervals listed in the maintenance part of the owner's manual. The only thing I'd say is avoid synthetics. I am not totally sure about the later T56s on the LS1 cars, but I know at least the earlier ones have like a paper seal or something that synthetics eat at. Sorry I'm not being more specific but the exact details escape me right now.
Old 03-26-2010, 09:33 AM
99FormulaM6r's Avatar
I called Tremec and they recommended Mobil 1 Synthetic ATF....I'm using their instructions It's the only synthetic they recommend in their transmissions. Also, the 97+ T-56's I believe switched to carbon fiber from paper seals.
I guess I think that an extra few $$$$ to help the transmission maybe last a little longer or shift a little smoother isn't too bad, and I've heard changing fluid at 30k intervals is recommended. I suppose it won't really hurt anything if you dont tho
