Cant shift at High RPM??
I'm in the same boat! My stock clutch was sticking, so I replaced the slave ,master , and the clutch with oz700. Now I can't shift fast Aka just slam gears. It sticks in between shifts. I replaced my master and salve with oem AP parts from orileys. Going to get the tick next and hope the shifts will be smooth,I can't stand not being able to just stab them!!!!!!
uh yeah, get the tick adjustable. had the same issue with mine after installing a monster III, the tick does wonders. For comparison, when I use to bleed my clutch stock, I could pump, hold, and open the bleeder probably 30-40 times before having to refill the resevoir, after the tick install, I have to keep it filled every 8-10 pumping cycles to keep it from going dry, thats how much fluid this thing moves. buy it, you wont be dissapointed. Oh, and get their speed bleeder too.
I put a remote speed bleeder in 2 weeks/300 miles ago and haven't noticed any leakage. Tick advised me not to use any teflon tape or sealant and that there's no torque spec to tighten down the fittings since they use a crush washer. I just tightened the hell out of them (probably too much now that I think about it) but all good so far.
I am having the same issue. I'm going to start by bleeding the system with new DOT4 using a vacuum bleeder. Then I will try a new Tick Master cylinder.
This all started after my Monster stage 3 premium install.
