The Truth behind Adjustable masters
I have seen a lot of post about how Adjusting the master will help your tranny shift easier.
There are only two ways a properly operating master can affect the trannys operation.
One way is if you have the pedal set to engage right off the floor.
The master has a piston in it.
Weather it be a stock one or the Mcleod. This piston moves about an inch total.
That’s all that’s needed to disengage the clutch.
You need to leave yourself enough pedal travel to get this inch of piston travel.
If you have your pedal set too Low to the floor you will either, not disengage the clutch fully, or not at all.
An after marked clutch may be able to handle this better than the stock.
Reason being, The after markets tendency to be more of a binary clutch.
Meaning its more of an ON / OFF clutch.
The other way it can affect the Tranny is by having the pedal set too High.
With the pedal all the way up and hitting the stop or the switch, the Push rod going into the master should not have any pressure on it. The Pushrod should actually be what stops the upward Motion of the pedal.
The Piston inside the Master Has to reach its full up , or as I call it. It’s position of rest.
The reason here is, the pressure seal on the front of the piston HAS to come back far enough to clear the Holes leading up to the Reservoir. What happens here is, as your clutch wears down, the spring have to push back further, thus pushing on the slave and in turn pushes more fluid back to the master, This fluid it pushed up into the Reservoir. This is also true of Fluid getting warmer and expanding.
I hope this helps you understand the Master cylinder a little better.
So where do you think would be the perfect position to set the pedal at? I'm just curious because mine is adjusted all the way at the top of the pedal travel.
Ryan
Ryan
Thats why No one puts that POS centerforce clutch in thier car.
Dump that clutch and get you a Spec.
The centerforce sucks on our cars. Do a search for centerforce clutches , and you will see others with the same problem.
Tom
A new master will not help. As far as I know.
Has anyone tried Centerforce about this? You can't adjust the plate for high rpms right?
