shifter noises
Old 01-19-2004 | 10:47 PM
amflaneman's Avatar
Default shifter noises
Is there anyone out there that has a pro 5.0 shifter that after installing the tranny makes a whinny noise in mostly 4th, 5th, and 6th?
Old 01-19-2004 | 11:12 PM
Onyx Z's Avatar
Mine does it too, but only at low RPM's in 4th, 5th, and 6th.
Ryan
Old 01-20-2004 | 08:31 AM
Bugsquawsher's Avatar
Did you install the Stops?
If so....
Take them out. Leave them off, the tranny has built in stops.
You Do Not need stops. They can actually Kill your tranny.
Old 01-20-2004 | 10:55 AM
Dal1as's Avatar
If so....
How is it that the stops can kill your tranny???!!! I have the stops in my B&M and have no problem. Mine are set almost exactly as the tranni stops though. Is it if you have them set too far in and the car isn't fully going in gear. Just wondering. I don't want to thrash my tranny.
Old 01-20-2004 | 11:07 AM
[QUOTE=. Is it if you have them set too far in and the car isn't fully going in gear. Just wondering. I don't want to thrash my tranny.[/QUOTE]
Exactly
These trannys Don't need stops.
I was sceptical too at first till I started rebuilding them.
Now I see what they are talking about.
The stops serve no purpose . But if the got loose and started moving , you might not notice till you blew the teeth off of a synchro or worse , a gear.
Old 01-20-2004 | 11:40 AM
Onyx Z's Avatar
Whenever my shifter is in gear, the stops aren't even touching the handle, so they can't be hurting anything. Right?
Ryan
Old 01-20-2004 | 11:57 AM
Leave them in if you want
Its your tranny.
I for one don't have any stops.
Take it for what its worth.
Good luck
Old 01-20-2004 | 01:02 PM
Dal1as's Avatar
I have mine installed so I don't bend the stops in the tranni on hard shift. Sort of a precaution. If installed correctly I don't see there being a problem. I'm going to check mine out to make sure. As long as they are set past the point of where the gear is resting I figure it should be fine. Thanks for the info!
Old 01-20-2004 | 02:44 PM
If you could see the stops in the tranny you would understand .
You would understand.
Old 01-20-2004 | 04:05 PM
Orange99Z's Avatar
Back to the first post. I saw where someone cut a gasket from rubber for the shifter and he said he barely noticed any increased interior noise. Don't know, never tried it.
Old 01-20-2004 | 05:43 PM
Cal's Avatar
Cal
Yeah the noise you hear is because you lost the rubber issolater when you took out the stock shifter. This bugged me at first, but then I got used to it. Yes some people use rubber gaskets or washers or a variety of other stuff.
Old 01-20-2004 | 06:01 PM
01PewterWS6's Avatar
Is this ture for the LSS (with stock Hurst) as well, i just put mine in and i hear weird noises in first second and third at low rpm kinda like a "lubricated sewing machine" sorry bad analogy only thing i could think of. Do you just get the noise since there is no issolator on the LSS?
Thanks
Wade
Old 01-20-2004 | 11:14 PM
Cal's Avatar
Cal
Yes, any stick that doesn't have the rubber thing will do that.
Old 01-20-2004 | 11:26 PM
Thanks, it was starting to worry me.
Wade
Old 01-21-2004 | 12:15 AM
jd13's Avatar
If so....
I must disagree here. My transmission had to be rebuilt because my internal stops failed. I've never heard of any others that have had this problem, so it very well could be isolated.
The built in stops of an aftermarket shifter will not harm your transmission if installed properely. Like said though, if adjusted incorrectly, very well could lead to a rebuild.
Old 01-21-2004 | 08:06 AM
SidewayzOZ's Avatar
Thanks
Wade
I have that same problem...how is it we can go about fixing it? Anybody got pics or info?
