Tick master works great but...
Hmm....well Ive always been told to replace the master and slave as a set. Ive had problems similar to yours with my jeep. I was told that having one unit wear out puts additional pressure on the other good unit and wears it out faster. I could never make sense out of this and dont understand why this would be true. Never the less ive always replaced both units at the same time. So, if its true, you may want to rebuild your master now that you have a new slave. In my camaro I just installed my new tick master with a new slave and new lines...but the car is still on blocks till i get the tranny back in. Ill let you know if I have any problems. I hope not to as now ever last part of the clutch hydraulic system will be new, including a new ls7 clutch assy.
Good luck and please post back if you make any progress!
I've had a couple other folks suggest the same thing. What would you recommend I use as insullation?
Location: Fairfax County, VA (You know you're here when you see the bad roads)
"Since the master was just installed last week, I don't think there was enough time between installs for one to wear out the other."
Iagree,
plus the issue your now describing sounds like a problem with the tranny, not the hydraulics. Im just learning the working of the transmission now so cant be much help on that.
Iagree,
Iagree,
Iagree,
Thanks alot for the advice. I'll look into it.
