Time for a new clutch, would like some advice.
Hey guys, my stocker is starting to go out (75k on it). Time to upgrade. What would you guys recommend? I was thinking of going with the CenterForce DFX, but I'm not sure. Give me your recommendations!
Also, what other components should I replace while I'm at it? Is the stock flywheel fine (I'll have it resurfaced)? Just wondering about parts such as throw-out and pilot bearings, master/slave cylinders, fork, etc.
Thanks in advance!
Thanks in advance!
It's a 2000 WS6 M6 with 75k on the ticker. Mods include:
-Dynomax O/R Y
-SLP LM1 Catback
-LS6 Intake Manifold
-BMR Panhard Rod
-BMR LCAs
-LG Motorsports Strut Tower Brace
-Bilstein Shocks/Struts
-Eibach Sportline Springs
-Suncoast Raptor Hood with true Ram Air and Heat Extractors
And a bunch of other cosmetic mods that don't come into play here. It's my DD, but it does see some time at the strip, and I'm hoping to have it blown by this summer with a Magnacharger. No LTs or Cams, since I live in CA (the blower will still pass emissions). So I'd definitely like a strong clutch, nothing extreme though. I plan to be running around 7-8lbs of boost. I don't mind a stiff clutch, as I had a Spec Stage 2 in my previous 2000 Mustang GT, and that thing was a calf workout.
Hope that provides a little clarity.
-Dynomax O/R Y
-SLP LM1 Catback
-BMR Panhard Rod
-BMR LCAs
for any aftermarket clutch you'll get 50 positive and 50 negative reviews, I couldn't decide so I bought a cheap stock replacement and it ended up ripping itself apart in under 5k miles
now I'm running a Diamond Stage 2 in my car and would highly recommend that brand. it's just about the only aftermarket clutch you won't hear of chattering, slipping, having springs fly off, etc. contact TDP or check out diamondclutch.com for pricing. you can resurface your stock flywheel or go with a lightweight one if you want it to rev up quicker, but they can be trickier to drive depending on how light it is
with 75k miles on everything go ahead and replace the master and slave. the slave should come with a new throwout bearing and the clutch kit includes a new pilot bearing. and with a 98-02 car you don't have a clutch fork.
Never heard of diamond clutches. Was just browsing the site, and they have a nice stage 2 kit for around $760. Just doesn't include the master cylinder.
Right now I'm looking at the Ram Powergrip HD clutch kit, with the Ram slave and adjustable master cylinder. Was just planning on resurfacing the stock fly.
All of that comes out to $742 on ws6store.com.
i've read several good things about diamond......alot of folks swear you can't hurt a Monster clutch and their Level 3 or 4 with a lightweight flywheel will probably be the next one I buy.....at 85k miles, i went with a Spec 2+, seems they get mixed reviews although mine has been excellent for 6,000 miles, pedal feels like stock, no chatter....look into upgrading to an aftermarket adjustable clutch master cylinder, they are literally worth every penny...... like creeper said, a new slave and pilot bearing are a good idea, as well as a remote bleeder line.
