Spec 3 = Bad MF'er
Spec 3 = Bad MF'er
Just installed a Spec in the car. Kick *** clutch, almost like stock driveability. I've got 25 miles on it and ZERO chatter. It's definately an on/off setup, but easy to drive as stock....
If anybody remembers about 3 yrs ago on LS1.com I used to bash the HELL outta Spec. I had one of their first clutch designs explode in my car after 1500 miles, killing my t-56 in the process. The old disk was a POS using rivets to hold the center section together, which sheered off causing .......We'll see how this one treats me. So far, so good....
Senior Member
Sweet, I have the 3I gonna be here tomorrow
well i like the way my clutch grabbs so far.. too bad i put 1000 miles on it (lots of stop and go conditions) and it still vibrates like hell sometimes... I sure hope this vibration goes away soon..!
the clutch i have is the new hybird spec 3 by the way. No "I" piece on mine though.
PR Director
Originally Posted by SlammedTA
What all did you purchase with the clutch. I am in the market for a clutch and I am considering the Spec 3 clutch. Did you use their flywheel or did you use your stock flywheel. Did you have to update your hydrallics?
josh
PR Director
Mike, you do NOT need their flywheel. That's a bunch of marketing crap, the stock steel flywheel works just fine. As for hydro's, your stock master will work but I would upgrade to the 2002 Slave cylinder. I am running a 98 master and 02 slave, shifts like butter
josh
josh
Senior Member
Originally Posted by 1320_PERFORMANCE
Whats the diffrence between the spec 3 and 3I?
The stage 3I has the drivability of the stage 3 but with the holding power of the stage 5 (800+ RWTQ) I believe the I stands for Iron disk.
https://ls1tech.com/forums/manual-transmission/134807-i-option-spec-clutches.html
1 Post
SPEC 3 and stock flywheel here...
I think I'm starting to have neck problems this thing grabs so hard
I have about 400 miles on it now. I'm totally happy with my purchase
