My car accelerates when I shift from Neutral to 1st?
Im assuming you are running the M6 bc you said n to 1...
Im not sure what could be causing the motor to rev up just by going in gear There is nothing electrically connecting 1st to the ecu.
Do you have any mods?
Yes, my transmission is manual. I park at an incline so I put it into first and apply the hand brake.
To back out, I remove the handbrake and put the car to neutral and let it coast back down.
During heavy traffic I constantly go from neutral to 1st (stop and go). That's when it usually occurs.
I'm pretty sure it is in the tune as well. If I'm not mistaken, it's the "throttle follower" or "cracker" table in the tune. Basically when you push in the clutch when the car is doing over 10mph, it will hold the rpm at "x" amount until the car gets below a certain mph. I hated it, so I tuned mine out years ago.
Mike
Mike
Mike
Mike
Sounds familiar, couldn't remember what it was called.....just annoying as hell and embarrasing as well. Nothing like coming to a stop light with your car all revving up and people wondering what the hell your problem is...LOL
Either that or I shift to first, then to reverse. That's the most used way I do.
