Stock trans strength ?
Old 05-24-2011 | 08:16 PM
Transamcrazy99's Avatar
Default Stock trans strength ?
I was wondering if anyone new how much work can be done to a 99 pontiac trans am or how much horsepower/tourque i can be pushing with a stock transmission.
Old 05-25-2011 | 10:46 PM
BrdofPry's Avatar
Has worked for me at 600+ Hp/TQ.
Old 05-26-2011 | 11:05 AM
bravolistick's Avatar
My stock tranny has sustained over 500whp since 2007, current numbers in sig, and it just let go in april.
Old 05-26-2011 | 12:03 PM
got-a-ls1's Avatar
let go at what though? 880 ft lbs of torque? LOL DAMN
Old 05-26-2011 | 12:07 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Too MANY varibles to calculate as factors such as weight, gearing, clutch, horsepower combo will weigh in.
Also the biggest factor is the driver, they can make a very tough/built trans blow up under stock power and a another who is careful make one last well into the 600 HP range.
I will let the Sponsors weigh in on this as they see more examples then I have in my years with the T-56.
Old 05-26-2011 | 02:57 PM
It let go at my current power listed in my sig.
I was cruising at 100mph in 6th, downshifted to 5th and rolled into the boost. (20lbs) Ran it to about 150+ and then put her in neutral. Coasted to a stop, without a hitch. When I went to put it back in gear she was toast. Sounded like a barrel full of wrenches. lmao Prior to that, there was not a single indication that anything had gone wrong. No weird vibrations, smoke, noises, nothing.
I chose 5th because I didn’t want to spin. All my down shifts before this are usually to lower gears, but result in serious traction loss which is scary @ 100+
The fact that I was actually hooking instead of spinning is what I believe destroyed my tranny. Otherwise, I think my tranny would have died much sooner. I've been told that with turbo’s the load is far greater in the higher gears.
As far as other variables, I have pix of my used flywheels and clutch disc’s to illustrate their even wear, and lack of any abuse or “hot spotting”. The car is a bit heavier than stock, stock gearing, with a OEM weight flywheel and a hendrix 6 puck. The rest of my drive line is built, (save for the diff for now ). The tranny was the weak link, and far over due to fail. I was on borrowed time.
Old 05-28-2011 | 02:30 AM
IWGF's Avatar
Mine has held up quite well, getting the **** beat out of it on nitrous at around 600rwhp/tq
Old 05-28-2011 | 02:49 AM
got-a-ls1's Avatar
its impressive it lasted as long as it did... thats asking a lot for a stock transmission, especially 5th gear blast
Old 05-31-2011 | 09:30 AM
indeed
Old 05-31-2011 | 07:24 PM
Man so theirs no real answer but thanks i have a rough range where is should stop with my mods.
