Indexing a Scattershield
Anyway back to the story:
So, the instructions talked about indexing aftermarket bellhousings. I never did that before and it was a new idea concept to me. So, I searched here and there and most people are like oh, you can't get the offset pins for a LS motor or you don't need to do it with Quick Times scattershield etc etc. Well, let me tell you BULLSHIT!
I stuck a dial indicator on the shield and it was so bad I couldn't tell which way to move it.
Luckily my tranny was apart so I mounted the tranny front plate to the scattershield and indexed off the input bearing race support.
Now the readings made sense.
Well, I was able to determine that I was like .022 off center. Thats an awful lot more than the .005 the spec calls for, so I ordered offset extra long pins. They only come in .007 increments so I need .014 as you need half of your total runout.
They came in and what a nightmare it is to find exactly where they need to go, it seems straight forward but I spend half the day spinning them around and remeasuring. It all finally came out and I was able to get just to the allowable spec. .010 total or .005 +/-
Look carefully at the final numbers on the scattershield, thats why I couldn't index off it is egg-shaped.
final note: I will always index my bellhousings/scattershields The amount it was off surely would have ruined something, clutch tranny etc.
ed
When installing an aftermarket scattershield, measuring is what needs done to assure the amount of runout (distance the input mis-matches crank center) is not excessive.
In the above well documented example, he installed offset pins in the block to re-align the QT so the runout was within spec.
Tedious, but necessary and straightforward work.
Ed
PS that clutch is sooo streetable I love it.
Ryan
You put a dial indicator on your crank flange or flywheel. I made a bolt on bracket because I already had the flywheel bolted on and it was aluminum and the dial indicator magnetic base won't stick. So anyway you mount the dial indicator to you crank and have it read off the bellhousing opening. You then rotate the crank and measure the total runout. You divide that half and the is the pin offset you need. You only need to worry if its over +/- .005.
You then need to install the pin so the opening is in the middle, ie equal runout on both side.
Ed
Ryan
Ed
I've never used them, but they look nice! Much easier than drilling the block.
