t56 upgrades
Any upgrade kits or mods you would recommended, other than the Rip shifter. Is there a multi plate clutch available?
Refresh that one with billet 3-4 keys, new blocker rings throughout, front and rear seals, depending on year a new iron 3-4 fork, careful inspection of bearings and all the synchro and gear teeth... If you're not going to hammer it with slicks the small output shouldn't be a liability but can be.
What's the tag # on the gearbox and is it a 6-bolt rubber coupler at the front end of the driveline?
921102YS B1523
TUET1877 AA 01254
Will look into the Spline upgrade, cheers.
jmd has you pretty much covered,, I also upgraded the blocker rings to CF, upgraded the output shaft bushing, added bronze fork pads & got billet forks & keys & had my gears get the mikronite treatment.
check out these guys for good deals on parts> http://ddperformance.com/
and check to see if tick has parts yet for your ride, their website says "coming soon"
http://tick-performance.com/
