Tranny Mount causing y-pipe to bang?
Old 03-18-2004 | 12:32 PM
LS1BirdDRG's Avatar
11 Second Truck Club
Default Tranny Mount causing y-pipe to bang?
I had my exhaust tweaked on by a muffler shop after my header install to stop the Y from banging but now it's doing it again. Seems the tranny mount could be the culprit. I'm not 100% sure, but has anyone tried or heard of poly tranny mounts?
Oh yea, the car's a M6. I'm not sure if another stock mount would last very long if that's the problem. Thnx. Any info appreciated!
Old 03-18-2004 | 02:22 PM
Joe "Preachers Sheets" DIESO's Avatar
Humanitarian
Make sure it's the mount, it could be the y-pipe hitting the driver side floor or the left header hitting the frame of the car.
Old 03-18-2004 | 02:51 PM
VoodooWS6's Avatar
True, I had that problem! check it out..
Old 03-18-2004 | 10:16 PM
14u2nv's Avatar
You could try a 1LE mount first. Some guys have experienced false knock from using a poly-mount. The 1LE mount is stiffer then the OEM mount but not as solid as the poly unit.
Old 03-18-2004 | 11:12 PM
1BadMoFo's Avatar
After taking mine off 3 times I've got my jet Hot Y to the point where it is good under normal driving, but under HEAVY torque it bangs under my drivers seat...I'll be installing a new tranny mount soon as well, hope it works...if not, then I'll try engine mounts.
Old 03-18-2004 | 11:52 PM
JimmyY2KWS6's Avatar
I used to have the stock Y-pipe bang even when I had the 1LE, when I switched to a poly mount it doesn't bang anymore. Now I have a Hooker LT w/ORYP and it doesn't bang at all. Get the Poly trans mount and that should fix it. I used to hate it when I shift into second and my y-pipe bangs the hell out of the car.
Jimmy
Old 03-19-2004 | 11:50 AM
Z28Venom's Avatar
If you're hearing a knock when your in the process of taking off or slowing down... It may be that you need to notch the K-Member..
You can definitely tell the difference between the k-member knock and the y on the floor board..
I hope you get this worked out..
Old 03-19-2004 | 11:53 AM
1BadMoFo's Avatar
My K member is notched, that's another long story. That is my second drivers side header because even when I put the notch in the K member, it would still hit on take off. Jet Hot replaced it, and it's been great since.
I have some definite Banging under the seat on hard take offs, that I hope to fix in the next 2 weeks with a new mount.
Old 03-19-2004 | 06:28 PM
LS1BirdDRG's Avatar
Thanks for the responses, I did notch the k-member and it's definately the y-pipe banging again. It only does it on takeoffs and hard shifts to 2nd.
My tranny mount seems to be flexing alittle more than normal I guess. A guy at another muffler shop said it was cracked and there was no need for them to bend the exhaust down anymore until I got a new mount. I'm still wondering about the poly mount though, I wouldn't think it would throw a knock code would it?
Thanks again for the help, I NEED to order a mount!
Old 03-19-2004 | 07:03 PM
1BadMoFo's Avatar
bought mine today, should go in within a couple of weeks...and what's this about throwing a knock code? never heard of anything like that...
Old 03-20-2004 | 12:52 AM
Cool
Originally Posted by 1BadMoFo
....and what's this about throwing a knock code? never heard of anything like that...
I have had my poly mount for about a month and no KR whatsoever.
Jimmy
Old 03-24-2004 | 12:45 PM
1BadMoFo's Avatar
I've had quite a few people warn me abotu the increased drive train noise becaues of the Poly mounts...is the 1LE mount a stock item at GM? I guess I'll calla round and find out.
Old 03-24-2004 | 06:33 PM
Dal1as's Avatar
Go get another stock tranni mount and have someone weld a valve spring between the y-pipe and floor board. That will solve your problem.
