Something definitely broke, but what?
After a day of spirited driving, my car completely locked up while driving home as if I slammed on the breaks. I was able to limp a few miles until the gears started to grind, I couldn't get in some gears at all, and it started violently locking up again, at which point I decided to get it towed home. The car starts, but definitely doesn't drive. It goes into all gears while the car is off, but not when driving. Help a noob out guys, what did I break?
Also, the car managed to pop itself into first gear when we started rolling it, causing the car to start itself.
http://www.tickperformance.com/1993-...camaro-trans-am/
Yes sir. You'll need to either have someone look at it or replace it with another unit. The T56 doesn't usually lock up like that unless it was ran without oil but that doesn't mean it can't happen.
Sounds like you broke a shift fork to me I had the same thing happen it could get expensive. If the gears were grinding you probably tore something else up when or if it broke could be Half away in a gear and when you go to another gear it's still in that one. While At the same time you can't get it in the one it's broke because your shift fork is gone.
