where are the leaks comming from? pics inside
today i noticed a leak under the car (1999 4.8 with a 6 speed t56) raised it up wiped it all down the waited like ten minutes and saw that it was leaking from3 differant spots , checked my oil and its low about a quart. transmission shifts fine . and also noticed 3 bolts are missing that hold the tranny(3 bottom bolts to tranny).
The Slave, Master, and clutch where replaced two years ago, but the car Sat for around 9 months.checked the clutch fluid and it was a Lil low and black.could it be the rear main deal also?
Did recently swap out the cam sensor and oil pressure sensor a few months back, and the engine shakes because of the big cam inside, Ima pull the ls6 intake and check everything, thanks guys.
