Leaky Tailshaft R&R
Here's the problem, leaking tranny fluid where the driveshaft meets the back of the T56 tailshaft.
I called D&D just to see what they would say and they say the GM only sells the entire tailshaft unit, but says you have to remove the unit and press the bushing in at a shop. He says the usually dont sell it because something going oblong or something.
Anyways, is there anyone thats actually done this and can give me some pointers? I've searched and checked all the LS1 how-to pages I could find. Thanks.
So it's leaking where the driveshaft slides in to the tranny?
D&D sells the rubber seal that goes around the driveshaft. I know, because I have one from them sitting in a box in my garage.![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Now, if you're talking about the surface that the driveshaft rides on, then that may be a different story altogether. I haven't ever replaced one of those on a T56, but I did replace it on my SuperT10 (my 79Z). Wasn't a big deal for that part.
If you overfill the tranny and go up a steep incline, the tranny will leak. A buddy of mine has a roll-back trailer, and his tranny leaked when he pulled his car up on it because of the angle.
If you overfill the tranny and go up a steep incline, the tranny will leak. A buddy of mine has a roll-back trailer, and his tranny leaked when he pulled his car up on it because of the angle.![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Well, aside from the metal bearing-type thing that the driveshaft yoke rides on, the rubber seal that wraps around the driveshaft as it enters the trans - the only thing in there is a rubber bumper that goes between the driveshaft yoke and the first snap ring that holds in the VSS reluctor wheel. This rubber bumper does not show up on some T56 exploded view drawings. I don't know if it really acts as a seal, or as a cushion.
As for pics.
As for pics.
![Naughty](https://ls1tech.com/forums/images/smilies2/naughty.gif)
Originally Posted by NastySSoo
Mine is leaking also. Im wondering if the rubber seal will correct it? Anyone know the part # for it?
I'll get it for you, I have the part sitting in the garage, it looks like a bitch to get this seal out with the trans full assembled because the splined shaft is in the way...arggg
Thanks, Camaroholic
