GTO t56 tail housing and shifter options
I got some trouble figuring out my shifter and tail housing options. Let me start with I bought a GTO t56 of a member here knowing I had to replace the tail housing do to it being cracked. It came with the GTO shifter and I noticed it pretty far back in my chevelle. I think its going to have to move forward. Can I just buy a camaro tail housing and swap all gto sensors, internals...etc over and use the camaro shifter or should I just buy the GTO tail housing and theres a way to mount the B&M camaro shifter on that?
BTW I don't have it yet but I plan on using a GTO interior (dash, seats, center console..etc) if anyone has done that in a A-Body how did you deal with this problem? I have one inch set back motor mounts so if I move the shifter forward to camaro location I hoping it will line up with center console.
the gto and camaro tail housings are the same part. so swapping will do you no good. what you need to do is go by the camaro shifter offset piece and swap it with the one in your gto t56 this will move the shifter forward to where it sits in a camaro you will also need the shifter from an fboduy. nothing else is needed.
LS1TECH Sponsor
Here is the part you need on our site. As redbird555 said, this is all you will need to swap on a GTO transmission in order to use an f-body shifter.
http://www.tickperformance.com/treme...y-cobra-viper/
And here is the tailhousing that fits a GTO or F-body since yours is cracked:
http://www.tickperformance.com/treme...ng-f-body-gto/
the web site says it won't fit the GTO trani
http://www.thegearbox.org/catalog/it...17/7328789.htm
Since you're wanting to convert to an F-Body shifter, this is the one you'd need.
I'm trying to do the exact opposite an put a T56 out of an f-body into my Gto. Does a yone know if they sell the same shifter offset to do so? Also is that the only thing needed? I looked on gearbox.org, but didn't see it.
