Do I need to shim?
After the shop got it back together, it is not fully releasing the clutch. While in nuetral, you cannot get it into any gear and when you are in 1st, it will take off when you release the brake. It seems that I need to shim it but how much? I have no clue!
I took it home and bleed the **** out of it tonight and it helped a little but still not good enough. Not sure if driving it a while would help or hurt. I need to drive it for 500-700 miles to properly bed in the kevlar before any agressive driving. That's why I'm worried to drive it while it's not disengaging all the way.
Is the Textralia thinner than the OEM flywheel? I went with it cause it's lighter than my stock one but the difference in the pressure plate makes up for it. Overall, I am runnng a 48 lbs clutch compared to my last combo of 53.2 lbs. My stock unit was 51 lbs. These numbers may not be accurate to others but they were done on the same scale so it is an "apples to apples" comparison.
Otherwise. How would I have my shop check for the proper size shim? Is there a "stock measurement" on the forum somewhere and from where to where do you measure? BTW, the clutch is smooth and holds great. No chatter or shudder like the ceramic before it.
Any and all help appreciated.
OEM vs Textralia
The guy that sold me the flywheel sent me the tickperformance measurememt page. I guess I'll take it back to the shop and have them pull it again.
BTW, my tranny guys are awesome. I gave them the clutch and they put it in for free after warranting and paying for my 5th gear that was not covered by the supplier. They ar the best. I told them I'd take it home and drive it a bit and re-bleed the slave so they wouldn't have to keep it another day. After not having it for 4 weeks, I was in too much of a hurry.
The owner even let me use his utility trailer to move some furniture for a few weeks. He was even going to le tme use his truck since my GTO was in the shop and was the only vehcle I had with a hitch. I went ahead and put a hitch on my wifes Murano instead. How's that for good guys?!
Here's the damage they fixed for free.
How much of a shim do I need? Thanks all!
For anyone who needs help, send me a PM and I'll let you know what I did. Looks like no one used this particular combo before.
The measurements I sent were right. I got my machine shop to make me a .260" shim and it put it right where it needed to be. I can't believe the Textrailia flywheel is that far off compared to OEM . I was told the pressure plate is the exact same as the one I replaced it with, just a little softer pedal.
If you are thinking obout replacing your clutch master, DO IT! You won't regret it. The guys at Tick Performance are a great bunch of people. I went in person to buy it and they gave me a tour of their new facility.
Awesome place!
