Is it okay to run a lt1/t56 with 5 out of the 6 flywheel bolts??
All of the the holes have been helicoil'd and one of them is messed up inside there and I cant get it out..what should I do? The other 5 are torqued to 75 ft lbs.
Ahh man! I would say one of the worst areas to have stripped threads. I don't know how reliable heli-coils would be in that area...But definitly DON'T run it with one missing.
You would probably not suffer any issues, but don't risk it. I would go as far as paying to have it professionally repaired.
Agreed, no bueno! You will see a greater potential for deformation and flex of the flywheel because of the lack of this bolt. Additionally, this could, in time, cause other bolts to see greater stress than normal causing the back-out or fail. Do it right or expect to do it again!
Save the manuals!
You should have some options - but what does this mean? Did the coil go in wrong? Is a bolt in wrong? Was the coil threaded in properly? Do you have a picture?
ever seen what happens when a flywheel or flexplate does when it comes off? this is why i want to invest in a tranny blanket or somethin for added safety. i enjoy having two legs and feet lol.
*ignore the stupid music*
The SRX shares the 04-07 CTS-V lug pattern and its just a slow poke V6 SUV. I think somebody had some spare part's to get rid of is what I think lol
Save the manuals!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
We could probably do a study of the number of studs, the diameters, and the torque applied to tell what the true strength difference is.
Beyond strength, balance probably also plays a role in rotating parts. Leaving off one nut or bolt could cause a wobble, which is usually a bad thing...
Why are you torquing a lb over max? Suppose to be 74 ft lbs... Also you have messed up threads? You stripped them out? Not to sound like a bad guy but maybe take a step back and figure out if this is something you should be doing... Also so..use 6. Take one of the bolts down to ACE or your local hardware store and they should be able to get you a bolt.
