spec stage 2 break-in
Ok drove around about 500 or so miles a lot of stop and go driving some highway took about 2 weeks barely have any chatter.. I heard after the 500 miles you take it to 6k and drop the clutch is this true ? Why take it to so high of an rpm and dump the clutch ??
Captain Double Post
Lol hope yours lasted longer than mine,had mine in for 2 months and that pos clutch trashed everything,and it will be necessary if there is an issue you will hear 1, clutch was installed wrong,2,it didnt seat yet,3 debris caused it,4,please send us the clutch so we can figure out what happend ,5 debris caused the fail its not under warranty
That is not a prescribed part of the break-in process. Not sure where you heard that but I think they were likely yanking your chain! Of course, once you are through with break-in you can can start using the clutch more aggressively!
