Recommend me a clutch pls...
Going into a 2002 ls1/t56 thats being put into a ~3200lb M3.
Cam only, plan on around 420whp.
Daily driver friendliness and road course tracked occasionally.
Do i need a new flywheel also or can i resurface the stocker?
Nothing super high dollar please.
Also anything else i should replace while im in there?
Thanks!
Thanks!
Ive tried in the past to reuse the OEM flywheel and it did ok but ive had better results with just buying a complete set up...balanced as a unit...
At your power level Monster Level 1 or Level 2 single should be fine an they are great to deal with.
Just had Tick Performance install a Monster Level 1 Twin and after only 200 miles or so it is starting to smooth out nicely.
Sounds like an awesome set-up, LS1 powered BMW's are always fun! I would suggest our Stage 2+. You can use a stock LS1 flywheel if you like but we also offer a Billet Steel and Billet Aluminum option as well. If the flywheel you have is used it needs to be resurfaced and if it has been cut previously it really ought to be replaced. I have provided a link to our LS1 part below. Reference the second set of parts on the page and let me know if you have any further questions. Thanks!!
http://www.specclutch.com/cars/Chevy/Camaro/2000/Single
If cost and DD ability are a factor look into the LS7 system. Your cars weight and power output are similar to the Corvette it is designed to work in. The FW/disc and PP can be had for under $500. Nothing feels more like a factory clutch more than a factory clutch.
