First time out with new McLeod RXT
Installed new McLeod RXT clutch in my stock shortblock SS.
Broke clutch in and went to LSX shootout in Indy.
Super happy so far with this clutch.
Got back to back 1.37 60' . Clutch seems awesome so far!
I'm very near purchasing that clutch. Everything I've read about it is very positive, stock like pedal pressure, modulates nicely on the street, bites.
My only concern is Hi RPM shifting, I dug thru your build thread (very nice BTW) trying to find your power level & shift rpm. Seems to be TSS Top Super Secret
Would you comment on shift RPM, lift?
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I shift at 7100 rpm's. The stock shortblock likes it!
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
What style flywheel and brand are you running?
Type of master cylinder?
Does this clutch require shims?
Work with stock T56 bell housing?
Style of slave?
Does it require balancing or can you just install it?
Special install instructions?
Why did you pick RXT over RST?
If desired, could you run this with a stock LS1 flywheel?
i was debating on getting this clutch as well. few questions:
Style of slave?
Style of slave?
2.McLeod adj master
3. No shims.
4. Yes, works with stock bell housing.
5. GM slave
6. No balancing
7. Nothing out of the ordinary for installation
8. Rxt is good for 1000hp so I wanted room to grow
9. Should be able to run stock flywheel
