Dragging clutch?
I was given the suggestion to block the rear end up and see if the tires still turn when the clutch is depressed. When I did this my tires only turned when the gear is first engaged. After about a second the tires stop rotating. Is this symptomatic of a dragging clutch? I'm at my wits end on this thing guys. Thanks for any help
It suggests your hydraulics are in need of bleeding or repair. Bent clutch forks or lose fork mount bolt are other reasons but hydraulics are more likely. Also if your clutch is toast and disc gets warped or TO bearing is seperating (lip peeling back) than that to will result in disengagement issues.
look closely at your MC & slave for any signs of seepage of fluid around piston...if so the associated part is bad. if you are losing fluid that is a sign of leak.
basically not just one thing can cause this but hydraulics are 1st in line
when you replaced the MC without first bench bleeding, the angle it mounts can trap air.
you can remove the MC & slave & resovoir as a unit and bench bleed the MC.
So get it the bleed better, jacking the front and the back up like 2 feet (safely) and bleed it more. get the master tiped, and midy vac it a little while tipped. Maybe try that if its easier then pulling the master out.
