What's the drill mod
Old May 6, 2004 | 02:17 PM
locosteelersfan's Avatar
Default What's the drill mod
I've read a few posts of guys with M6 talking about
the "drill mod". Anyone know about it. Pros/cons
THANKS
Old May 6, 2004 | 02:44 PM
Bugsquawsher's Avatar
Drilling out the inside of the Hydraulic line at the Master cylinder end of the Hose.
All Pro , No CONs
Old May 6, 2004 | 03:04 PM
All Pro , No CONs
So what are the advantages.
Old May 6, 2004 | 03:11 PM
Fluid can move faster. ( bigger hole)
That means the Clutch will engage faster.
Old May 6, 2004 | 03:12 PM
Someone should Post up the link to the How to on this
I dont' remember where its at
Old May 6, 2004 | 04:36 PM
1ScrudeDude's Avatar
I thought I saw it on Chevy High Performance online....it's at home, I saved it. I'll link it up tonight if no one beats me to it.
I'm doing the mod for sure.
Old May 6, 2004 | 04:48 PM
Its not real hard
You have to remove your Master,(if it's never been removed this is a pain in the ***)
There is a Clip ring that you can't see, but once you know about it, well it's easier.
You have to disconnect the line from the Slave from under the car. Its a Quick disconnect.
once the whole thing is out.
you remove the Line from the Master , by punching out a pin, then you drill out the inside of the fitting that goes into the master.
Make sure you get all the Crap out , put it all together , bench bleed the master.
You might need the Step by step. I'm gettin tired of typing.
Didn't install university have this too?
I'll check
Old May 6, 2004 | 04:53 PM
Yea
Goto www.intalluniversity.com
Hit the intall documents button on the left under Main.
Then scroll down to Transmission
look for Drill mod, mcleod master install.
Old May 6, 2004 | 07:05 PM
You have a choice!
http://www.chevyhiperformance.com/howto/39021/
Mods, can we sticky stuff like this?
