Grinding when shifting into 4th
Old 05-25-2014, 08:05 PM
Goodkat's Avatar
Default Grinding when shifting into 4th
I was wondering if anyone else has had this problem sometimes usually when car is cold it will grind while I shift into 4th gear not always but sometimes im doing everything correctly driving wise any advice on what the problem may be? 98 Z28
Old 05-26-2014, 07:56 AM
superspirit's Avatar
4th gear synchro ring is worn or sticking, might check your fluid level and condition
Old 05-26-2014, 08:35 AM
redbird555's Avatar
this... if its multiple gears then its most likely hydraulic problems however if its just one gear its probably a synchro. try a fluid change first
Old 05-26-2014, 05:43 PM
Goodkat's Avatar
Will try fluid change hopefully it works thanks for the input.
Old 05-27-2014, 04:06 PM
SNLPerformance's Avatar
I'd recommend swapping the fluid in both the transmission(Dex3) and the hydraulics(Dot4), report back on how that helps. Curious how much power it makes?
Old 05-27-2014, 07:45 PM
Goodkat's Avatar
Thanks I will post as soon as I get it changed
Old 06-03-2014, 01:26 AM
Goodkat's Avatar
Finally changed the fluids was gonna try changing just the tranny but decided to just get um both outta the way they were far past due anyways hasn't grinded yet so fingers crossed its case closed. Thanks for all the input.
Old 06-03-2014, 03:05 AM
RSAXON1979's Avatar
To check synchros you can start the car and while its in neutral try to push the shifter into gear without the clutch (make sure you have your foot on the brake) if it won't go in its good, if it tries to go into gear or starts to grind the synchro is either bad or going bad.
Old 06-03-2014, 06:34 PM
Goodkat's Avatar
Oh sweet I was worried if it started doing it again I was either gonna make a mess of it myself or get rapped by a shop but this method is retarded easy thanks bro.
Quick Reply: Grinding when shifting into 4th
