Does unplugging the cags to the tranny just cause a ses light?
Old 05-28-2004 | 10:33 AM
hourang's Avatar
Default Does unplugging the cags to the tranny just cause a ses light?
I want to get rid of cags, i already have the ses lights for the !AIR !EGR and was just thinking i could just unplug the cable going to the trans or would this cause a problem? im getting it tuned soon so i dont care about the ses light. thanks.
Old 05-28-2004 | 03:41 PM
Camaroholic's Avatar
Yup. That's all it causes. If the ses light is already lit... why not.
Old 05-28-2004 | 03:43 PM
Tiago's Avatar
sweet witch one is the correct oen to pull ?
Old 05-28-2004 | 05:02 PM
2001CamaroGuy's Avatar
the one back by the shifter on the drivers side at the very top.
Old 05-28-2004 | 05:47 PM
rushman's Avatar
Um, thats the reverse lockout noid isn't it?
Old 05-28-2004 | 05:56 PM
hourang's Avatar
sweeeet, yeah which one is it?
Old 05-28-2004 | 06:45 PM
Reverse lockout is on passenger's side. CAGS is on driver's side.
Old 05-28-2004 | 06:53 PM
TransAm52804's Avatar
Hmmmmmmmm... I reckon I'll give it a shot.
Old 05-29-2004 | 11:10 PM
zombiedude's Avatar
Do a search. I put a resistor on the connecter and no light and all is good. I can shift to 2nd while the skipshift light is on. You might be able to do the same with the other 'light' problems. I did on other issues.
Old 05-30-2004 | 10:22 PM
jmd's Avatar
jmd
Andrew, you know better than that.
reverse lights is on maincase, PS of tranny
reverse lockout is on tailhousing, DS of tranny
computer aided gear selection is on maincase up high, DS of tranny
CAGS on right hand side of photo:
Old 07-02-2004 | 05:45 AM
robin427's Avatar
What are the benefits of wiring the 2.2 ohm resistor into the plug versus removing the wires from the EMC connector?
I don't care about lights - I haven't got any to be lit! I don't want the ECM throwing some code that makes it cry, though...
Old 07-02-2004 | 06:14 AM
SPG's Avatar
SPG
Robin It just throws a code, and sets a light, you won't see it, but I may be able to delete all that stuff in your ECU anyways - you have a 2002 right?
Old 07-02-2004 | 05:48 PM
robin427's Avatar
Hello, Steve...
I meant to ask you - does having the gearbox in a right hand drive car make the dreaded 3-2 shift less of an issue, since you are naturally pulling to the right?
Old 07-03-2004 | 09:37 AM
SPG's Avatar
SPG
Robin. I got rid of the GM "mushy shift" gearstick, and replaced it with a solid shifter.
After that I have not had any gearshift issues, I have had to put a forward kink in the shifter though, just to get the shifter into a good location for me.
I also think I have deleted the CAGS stuff from my ECU, so I have a spare CAGS delete connector
Old 07-03-2004 | 11:29 AM
robin427's Avatar
Do you have any photos of the shifter? Is this a replacement that involves more than undoing the two bolts on top of the gearstick?
Old 07-04-2004 | 04:28 AM
SPG's Avatar
SPG
Robin no pics, but it is only the two bolts at the top, I didn't replace the whols shifter, just the "short stick"
Old 07-04-2004 | 11:20 AM
robin427's Avatar
Can I not cut down and thread the original shifter then?
I think even I could manage to bolt one of those on!!
Old 07-07-2004 | 08:16 AM
SPG's Avatar
SPG
you can, but you still have that rubber part on the shifter which gives a "mushy" feel to the shift
Old 07-07-2004 | 12:29 PM
hourang's Avatar
yeah get a lou short stick or something
