MN12 VS T56 magnum
MN12 VS T56 magnum
I've done a little researching, but nothing substantial comes up. I'm curious what the differences are between the MN12 and T56 Magnum internally. As parts are getting hard to find, and prices over inflated, would it be beneficial to "convert" the MN12 to Magnum status? Can it even be done? I've heard the Magnum may have larger gears, but does that mean the synchro design is different as well?
Thanks for any input and expert knowledge.
Ok more questions.
Does the t56 mag fits any ls motor but for gen 3 you need to use the earlier pilot bearing right? How abt the spline? It that the rear of thetrans that connect the driveshaft or is that the one that goes into the motor.
Which is better upgraded stage 3 t56 viper or getting a t56 mag? Jason from tdsp said that he is going to discontinue the stage 3 builds due to some of the part being discontinued.
Or you can buy an OEM LS Camaro T56 fitment Magnum from the transmission builders like Tick, RPM, DD etc
Tremec themselves were to be making a Magnum direct replacement...for some reason this has been shelved.
