MGW Shifter is off center?
Anyone who has an mgw shifter have this issue?? The lever holder (for lack of better words is adjusted facing me, so i know thats not the issue.. Maybe a build defect?
Also noticed my shifts are very notchy with difficulty getting into reverse..
Trans is an mn12 t56 from an 05 GTO
Here you'll see the adjustments I noted earlier
![](http://i1188.photobucket.com/albums/z401/mosalaam/Mobile%20Uploads/20150204_162110.jpg)
Here's the problem
Here's the problem
![](http://i1188.photobucket.com/albums/z401/mosalaam/Mobile%20Uploads/20150204_161129.jpg)
I would see if those specs on the trans are the same. It may be because the MN12 has a different shift selector in the rear housing than the MM6 which came in our car. I would look it up further there though. Your poly mounts should have no effect on the location. Mine sits in pretty evenly throughout the center of the console.
Your issue is you bought an fbody shifter for a gto transmission I fear...unless you also purchased the adapter to convert it to an fbody it will not work....you may want to check on this as I don't know if you can damage the transmission....
George from mgw
George from mgw
When you say adpater, do you mean the offset shifter cup/lever that came in the gto tranny? Because I've changed that already.
http://www.mgwltd.com/mustang_shifter.shtml
Could i just buy your race handle and make the **** atleast face me? I find myself shifting into the wrong gear sometimes with the position its in already, so anything you can recommend that would either center it of make it face me would be best..
Also, i was looking at these handles you guys have
I will also add that my MGW shifter is also really notchy, but I attribute that to it not being broke in yet, and there will probably always be a level of "notchiness" to the shifter. I have no issue finding reverse however.
My MGW is also off center but doesn't bug me at all. Its a bit notchy but not as bad as the B&M. I've only driven it a couple if times. So after a few more days it should feel even better. I just have the old school looking white **** on there. I spun the **** on the stick then pisitioned the stick were the **** was in the right direction, tighten the 2 bolts on the stick to the base shifter and then pulled the boot down all the way. I thought I would need to cut the stick but it sat lower then my cut B&M so I was happy with the hieght.
