Clutch / Trans Issue
After inspecting the old clutch, there were some hot spots on it but was still in good shape. So my original problem was most likely the master or slave cylinder.
If after changing the master cylinder the problem is not resolved, I will probably contact a local shop to have a look at it. Tick Performance is about 20 minutes from my house.
Bought Tick Master (comes without the restrictor orifice)
Kicked self for not just getting the Tick.
Save yourself some trouble.
FWIW, the hose is 1/8". The restrictor puts the opening at 1/16". The purpose was to hamstring the clutch a bit to protect the Barbie 10-bolt from the combined destructive force of the LS1/T56. Slows the fluid down, so it won't hammer into gear. However, once you add the adjustable pressure plate to the mix, as the adjustor works, the return pressure weakens, causing inconsistent pedal return height. Very often, people find that to fix the inconsistent and/or dead pedal, you have to go to aftermarket non-adjustable PP AND an upgraded master. Hope the history lesson helps
Last edited by Darth_V8r; Jun 26, 2015 at 10:59 AM. Reason: Added restrictor detail
