Monster clutches has horrible customer service
I bought a stage 1 clutch and had nothing but problems. Chatter since day one, then clutch would not disengage. Their customer service is probably the worst I have ever dealt with. Should have gone with LS7 clutch in the first place. I am running Tick master and a LS7 clutch with no issues now. I would avoid Monster Clutches like the plague.
LOL this will get interesting.
Assuming you installed it right and shimmed the slave right and cleaned it before installing it...did you call Steve at Monster? Did you try to contact them on the forum? Ran a Stage 2 in my GTO with ZERO problems...LOVED the clutch.
I also spoke with Tick Performance, and they were very helpful. By the way great Master Cylinder! Works perfect with my LS7 clutch now.
Your Stage 1 wouldn't release completely or wouldn't release at all? I've been told the Stage 1 & Stage 2 pressure plates are the same, and I'm wondering if our issues are similar. BTW - My Stage 2 is really smooth, no chatter, just won't release completely.
The GTO was sensitive with shimming the slave without adj MC. Adding a adj. MC in the mix allows for more ability to have it set up wrong. If shimmed properly and installed properly, what's the fascination with adj MC?
Ive spoken to steve on numerous occasions before I bought the clutch asking questions and even spoke to him on a saturday afternoon when I had an urgent question during my install. Again I had no complaints and when it was all said and done I had no chatter and no issues. I made sure I cleaned the **** out of the FW. Cleaned it for 10min until I had no more dirt left on it.
By the way I had to pay mechanic labor twice. So I am out an extra $450 in labor cost. Plus I had to buy another clutch (LS7 $430 from ws6store.com) because your clutch left me stranded.
Clutch started not completely disengaging, then go to the point where it left me stranded. Clutch would not disengage at all.
Never mind, I already know the answer to that Adolfo.
I'm many things, patient and polite are two that I pride myself on. What I won't tolerate are people who try and yell and threaten me to get what they want... not going to work. Nobody told you that you were a nobody and nobody told you that we have bigger customers... LOL
You called irate saying the clutch wouldn't release after you drove it a while, we were going over things and you constantly said you just wanted your money back and that your tech never makes mistakes.
I ask you to pull it and send it back and, after going over things with you repeatedly even agreed to refund you in full if it was found to be defective. You declined that. That's when you tell me you're an engineer and when I start asking you simple questions your responses became more and more heated... you were being rude and completely unreasonable, completely. You didn't become belligerent until I started discussing friction coefficients and lever ratios that pertain to a pressure plate... strikes me as odd being you're an engineer and I was trying to explain things with logic, etc. All I was attempting to do was go over things with you to help you better understand where we are coming from.
Regardless, at this point you thought it would be a great idea to do a charge back while keeping the clutch... I don't like thieves even more so than I like belligerent customers. I gave you the options available to you, you didn't want to hear it and thought yelling and threatening would get you somewhere, that appears to have back fired on you. Now, considering what you've done, I'm not going to provide any support to you at all.
Good luck with your chargeback and your LS7 clutch.
Pressure plates work or don't, typically when you experience what you're describing it's hydraulics... that said, we never got the unit back here to verify either of our theories.
Your signature says Diamond Clutch... why are you in a Monster thread?
Considering you're an engineer it doesn't strike you odd that a mechanical lever would "sort of" work then not? You do realize how a clutch works, right?
I have said as soon as I receive my money your clutch will be shipped back to you at my cost. I am not trying to keep anything. Your clutch is worthless to me. It doesn't work.
All I am trying to do is get everybody inform of your customer service and your clutches having disengagement issues.
Nothing has backfired on me. I lost as soon as I bought your clutch. But all is good with me.
Good luck with selling your clutches that have disengagement issues and chatter very bad when you in fact say that monster stage 1 clutch is not suppose to chatter at all what so ever.
GM master was in at first. Then I replaced it with a Tick master to try fix the issue with the clutch. So it was not a hydraulic issues. I tried 2 different master cylinders. The slave was brand new. It was put on when the clutch was done the first time.
I sell thousands of clutches a month with thousands of happy customers world wide, I will continue to do so.
